Finding unit vector for magnetic dipole moment
10 replies · 3K views · last reply
kosmocomet
  • m=N*I*A
  • T=m X B
  • m = n(unit vector) *m
To calculate m, I know it is just plugging in the information. Thus, m=0.8. Now, the question is computing the unit vector, which has me confused. Using the right hand rule, and going along the current, The normal should look something like this, correct:
If so, how do I make this into an x(unit) and y(unit)?
Any help is much appreciated!
You have ##\vec {\tau}=\vec m \times \vec B##. What is the magnitude of the cross product in terms of the magnitudes ##m##, ##B## and the angle between the magnetic moment and the magnetic field? This is quicker than figuring out unit vectors.
Thanks, for the comment. I still am a little confused. The angle between the magnetic field and moment would be 60 degrees correct? If so, how do I apply this for a torque vector
Yes the angle between ##\vec m## and ##\vec B## is 60o. There are two ways of finding the cross product as shown here
http://hyperphysics.phy-astr.gsu.edu/hbase/vvec.html
You need to find the n[unit vector] components nx,ny,nz and to multiply with Bx,By,Bz vector
product. The n vector is located in the center of surface A and is equal with the difference between n1 and n2 [end vectors].In order to find the unit vector you have to divide each coordinate by the module=sqrt(x^2+y^2+z^2).[vector product=cross product]
So I understand how to do the cross product. The problem is I don't know how to define ##\vec m## as an x and y components like B is = Boy(unit vector).
Oh, that. This is what you do. (a) Make a better drawing than in Post #1 showing both x and y axes. (b) Draw in ##\hat n##. (c) Resolve ##\hat n## into its x and y components just as you would resolve any vector except that for magnitude you use 1.
Hmmm, i think i get it. Thanks.
Babadag said:
According to your drawing, ##\hat n =\vec {n}_{1y}-\vec {n}_{2y}##. This difference is independent of the choice of origin, so if the task is to find the difference, you might just as well put the origin at point a to make the algebra less involved.
