Finding Value of Inverse Trig Funct
The discussion focuses on finding the exact value of cos(arctan(2) + arctan(3). Participants suggest using the cosine addition formula, cos(A + B) = cos(A)cos(B) - sin(A)sin(B), and emphasize the importance of expressing cosine and sine in terms of tangent. A right triangle approach is recommended to determine the values of cos(arctan(2)) and cos(arctan(3)), leading to the conclusion that the answer is -sqrt(2)/2. The conversation also touches on another problem involving sine(2arcsec(13/5), where the same triangle method is considered. Overall, the thread provides insights into applying trigonometric identities and geometric interpretations to solve inverse trigonometric functions.
vipertongn
find the exact value of cos(arctan(2)+arctan(3))
I know that arctan(2) is equivalent to tanx=2 and arctan(3) is equal to tanx=3
I was thinking perhaps sinx/cosx=2 and 3 but I am not sure what numbers to use. I'm kind of weak in my trig rules =( can someone explain to me how I would go about this problem? I know the answer is -sqrt2/2 but I want to know HOW to do it.
I would say tan(y) = 3 since they are different angles.
It may be difficult to evaluate the cosine of the two angles if there's a quotient involved. Try separating the two angles by using the identities for adding two angles. Then you will just need to evaluate terms like cos(arctan(2)), for which you can draw a right triangle with a height of 2 and a base of 1. The angle of magnitude arctan(2) would be the angle adjacent to the base. You can then read the cosine right off the triangle.
what do you mean?
vipertongn said:
what do you mean?
Try using the identity cos(a + b) = cos(a)cos(b) - sin(a)sin(b)
How would i solve for x and y then? because like thinking it in terms of sin/cos=2 or 3 seems kinda hard
As slider142 says, use the identity for cos(A+B), where tan A=2 and tan B=3.
The idea now is to express the identity for cos(A+B) in terms of tan A and tan B.
For example, can you write cos A in terms of tan A?
OHhhh yes think of it like a triangle, the angle would be arctan(2) the sine would be equal to 2 and the cos would be equal to 1 and the hypotenuse is equal to sqrt 5. then when you use CAH it would be 1/sqrt(5) for cos(arctan(2) right?Yes i got the answer =D thanks
I got a new problem now ummm sine(2arcsec(13/5))
I went about using the similar method above but without the identity. but because of the 2 there I don't know how to get the answer...
do i use sine(2a)=2sinacosa?
ArcTan(3) + ArcTan(2) = 3Pi/4
That would be a straightforward method. :smile:
Thanks so much for all your help ^^.
  • · Replies 22 ·
