How Do You Find Non-Parallel Vectors in a Plane Defined by an Equation?
  • Thread starter Thread starter Cankur
    Plane Vectors
To find non-parallel vectors in the plane defined by the equation x + 3y + 2z = 0, one can select values for x and y to calculate corresponding z values. For example, choosing x = 1 and y = 0 yields the point (1, 0, -1/2), creating the vector i - (1/2)k. Similarly, selecting x = 0 and y = 1 gives the point (0, 1, -3/2), resulting in the vector j - (3/2)k. These two vectors are independent and span the plane. If x + 3y + 2z ≠ 0, the plane does not pass through the origin, altering its position in space.
Cankur
Hello!
I was just thinking, say, I have a plane with the equation x + 3y + 2z = 0. How would I go about finding two vectors in that plane (that are not parallell)?
Sidenote: I pretty much get the intuition of how a plane with the given equation would look but what would happen if x + 3y + 2z ≠ 0? How would that plane look?
Thanks in advance!
pick values for x and y, and use your equation to calculate z:
If x= 1, y= 0, then 1+ 3(0)+ 2z= 0 so z= -1/2. A point in that plane is (1, 0, -1/2) so the vector from (0, 0, 0) to (1, 0, -1/2), i- (1/2)k, is a vector in that plane.
If x= 0, y= 1, then 0+ 3(1)+ 2z= 0 so z= -3/2. A point in that plane is (0, 1, -3/2) so the vector from (0, 0, 0) to (0, 1, -3/2), j-(3/2)k, is another vector in that plane.
Of course, since those two vectors are independent, they span the plane.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 23 ·
  • · Replies 17 ·
