Finding velocity from a position-time graph at t = 5 s
  • Thread starter Thread starter Allura
    Velocity
6 replies · 5K views
Allura
[PLAIN]http://lc.cit.jmu.edu/cgi-bin/plot.png?file=safavifn_jmu_1283993422_6827202_plot.data
1. A bicyclist has the position-versus-time graph as shown. What is the bicyclist's velocity (in m/s) at t = 5 seconds?
2. Since this is a simple velocity problem, I thought it would be v= 60 m/ 5s
3. My answer was 12m/s
I don't know what I'm doing wrong, could it be that I'm reading the graph wrong?
velocity is the rate of change of displacement with time or v=ds/dt. So you need to find the gradient of that section from t= 0 to t=5. At what point does it cut the vertical axis? What position does t=5 correspond to?
So would it be (61-51)/5? Since t=0 is 51m and t=5 is 61m?
Allura said:
Thanks.
How would I do something like t=37s?
Then you'd need to consider the line segment between t=30 and t=40.
So get the position at t=37, that will be one point. Then get the position at any time between 30 to 40 (so t=31 for example). Then just use the same gradient formula you used before.
