Finding Velocity of a dropped ball
  • Thread starter Thread starter cowmoo32
    Ball Velocity
The discussion focuses on calculating the velocity of a baseball with a mass of 0.025 kg dropped from a height of 3.5 m. The conservation of energy principle is applied, where the potential energy (PE) at the height is converted entirely into kinetic energy (KE) just before impact. The potential energy is calculated as PE = m * g * h = 0.025 kg * 9.8 m/s² * 3.5 m = 0.8575 J. The final velocity of the baseball upon hitting the ground is determined to be 8.3 m/s, confirming that the total energy remains constant throughout the fall.
  • Understanding of the conservation of energy principle
  • Knowledge of kinetic energy formula (KE = 1/2 mv²)
  • Familiarity with potential energy calculation (PE = mgh)
  • Basic grasp of gravitational acceleration (g = 9.8 m/s²)
  • Study the conservation of mechanical energy in different systems
  • Learn how to derive velocity from energy equations in physics
  • Explore real-world applications of energy conservation in projectile motion
  • Investigate the effects of air resistance on falling objects
Students studying physics, educators teaching mechanics, and anyone interested in understanding the principles of energy conservation and motion dynamics.
cowmoo32
A baseball of mass .025kg is released at rest from a location 3.5m above the ground. You will calculate its speed at the instant it hits the ground.
Choose a sysem to analyze, and list the objects in your system.
I chose the baseball and the Earth as the system
Write out the energy principle as it applies to the system you have chosen. Solve for the speed of the baseball when it hits the ground
Here's where I'm lost. The baseball has kinetic energy (1/2mv^2), and the Earth is pulling down on it (-9.8*m), but I'm not sure how to arrive at the answer. According to the key, the answer is 8.3m/s.
If you are supposed to solve this problem using conservation of energy, you need to know the potential energy (PE) of the ball before it is dropped. How much energy did it take to initially lift the ball from the ground to the height h?
Wouldnt that be M*G*D? .025*9.8*3.5 = .8575
Yep. And what is the total energy (TE) of the system? What can you say about it? How does that help you solve for the ball's final velocity?
Total energy has to equal zero.
K+U+G=0
(.5mv^2)+.8575-(9.8*m)=0
correct?
or would it be
K+G=U?
I'm guessing that you mean KE for K, but what are U and G? I use TE=KE+PE myself.
oh, G=gravity U=potential energy K=kinetic energy
Gravity is not an energy. Different units, different concept. All the energies in the equation should have units of joules.
ahhh...ok.I'm still not sure how to find velocity though. If I have KE+PE=TE, I'm still left with 2 variables. Because my velocity is unknown for KE, then I don't have a number for TE.
moo, the concept here is that the TE does not change when you drop a ball. What is lost from the initial PE is gained in the KE. What is the initial PE from lifting the ball from the ground to a height h? Be sure to include units for all quantities in that equation that you will write. Then assuming that all that PE is lost and converted to KE in the fall, what is the final KE? What does that mean the final v is? I got to go now. You're almost there.
PE of the ball is equal to the KE of the ball as it hits the ground
That's not stated very well. More accurately, the TE of the ball is all PE when the velocity is zero (at the top), and the TE is all KE just before it hits the ground.
  • · Replies 24 ·
10K
