Finding velocity of a particle
  • Thread starter Thread starter science_rules
    Particle Velocity
The position of a particle is defined by the equation x = 2 + 3t - 4t^2. To find when the particle changes direction, the derivative is set to zero, yielding t = 0.375 seconds and a position of x = 2.5625 meters. To determine the velocity when the particle returns to its initial position at t = 0, the equation 0 = 3t - 4t^2 is solved, leading to t = 0.75 seconds. The velocity at this time is calculated as v = 3 - 8(0.75), resulting in a velocity of -3 meters/second, indicating the particle is moving in the opposite direction.
science_rules
The position of a particle is given by: x = 2 + 3t - 4t^2. Determine the position of the particle when it changes direction. Determine its velocity when it returns to the position it had at t = 0 sec. x is in met. and t is in sec.
I calculated the particle's position by derivating f '(x) = 3t - 4t^2 = 0
f ' (x) = 3t - 4t^2 = 0 = 3 - 8t
t = 0.375 sec.
x = 2 + 3(0.375) - 4(0.375)^2
x = 2.5625 met. position
My question is: would this be the correct way to find the velocity of the particle(see the problem statement):
3 - 8t = 0
3 - 8(0 sec.) = 3 met/sec. ??
t = 0.375 sec.
3 - 8t = 0
It works due to the fact that it takes the particle the same amount of time to go from it's starting point to the point it turns and from the point it turns around to the starting point. However, your answer is still wrong, but only slightly.
Hi science_rules,
t = 0.375 sec.
3 - 8t = 0
I believe you might have misread the question. They don't want the velocity at t=0, they want the velocity when it is at the same position at t=0.
In other words, what is the particle's position at t=0? At what later time t has the particle returned to that same position? Then, what is the velocity at that later time?
then would it be correct to use this equation to find the velocity?:
v^2 = vi^2 + 2aS i know S stands for the distance. i convert all numbers to met/sec.
= (3.0 X 10^6 met/sec)^2 + 2(1.196 X 10^15 met/sec.^2)(1.5 X 10^-2 met)
= (9 X 10^12 met/sec) + 2(1.794 X 10^13 met/sec)
= (9 X 10^12) + (3.588 X 10^13)
= 4.488 X 10^13 meters/sec
I don't see where you are getting these numbers from. Are you accidentally using the numbers from a different problem?
This equation in a sense applies to this problem, but it would be more of a conceptual approach.
My last post showed three questions to answer to solve this problem. They were:
What is the particle's position at t=0?
At what later time has the particle returned to that same position?
You already have the two equations in your original post that you need to answer these three questions, and the last question solves the problem. What do you get?
EDIT: I saw your PM, and I am only referring to part b of this problem. I believe the first part (finding the position where it turns around) is correct.
as a matter of fact i accidently used numbers-the 3 X 10^6 etc. from a problem right underneath the problem I'm trying to do in my book. i hate that! rrrghh. lol
if I'm not mistaken, i think i can use the quadratic equation to solve for t. i assume x is set to 2 meters because that is where i am trying to find at what later time the particle returned to that position?
so...
x = 2 + 3t - 4t^2
2 = 2 + 3t - 4t^2 now i believe i need the quadratic equation to find t.
ax^2 + bx + c
delta = b^2 - 4ac = 3^2 - 4(-4)(2) = 41
now i use the quadratic formula:
x = -b +/- squrtdelta / 2a
first x = -3 + squrt 41 / 2(-4) = -0.425 met.
second x = -3 - squrt 41 / 2(-4) = -9.403 met.
then i plug one of those into v = 3-8t to get the velocity.
this is where i am confused again. neither of those numbers seem right:
v = 3-8(-0.425) = 6.4 met/sec
v = 3-8(-9.403) = -72.22 met/sec
none of those are close to 3 met/sec. as it should be, but i think i used the quad. equation correctly. does it have to be near 3 met/sec?
oops i forgot to say that the later time is t = -0.425 sec. or is it t = -9.403? when (x = 2)
then i have to check if either of those times equals 2.
i mean, if when i plug in either of those times, it makes the other side of the equation equal to 2 meters.
it looks like the t = -0.425 is the closer one, but it still doesn't make the equation equal to 2 meters. darn. I am confused now. all this calculating and it seems I am not getting anywhere :(
2 = 2 + 3(-0.425) - 4(-0.425)^2
= 2 - 1.275 + 0.7225
= 1.44
so...
x = 2 + 3t - 4t^2
This equation is right, but you don't need the quadratic formula to solve this. First subtract 2 from both sides, and you'll get
<br /> 0=3t-4t^2<br />
With this, you can divide everything by t, and then solve what's left for the t that you are looking for. What do you get? (Once you get it, you can check it by plugging it back into 0=3t-4t^2[/tex] to verify that the right side does become zero with that value of t.) What do you get?
sigh. silly me. well, atleast i remember how to use the quadratic equation.
so, then it would be:
2= 2 + 3t -4t^2 subtract 2 from both sides.
0 = 3t - 4t^2
0/t = 3t - 4t^2 / t (zero divided by any number will be zero)
0 = 3 - 4t subtract the 3
-3 = -4t
-3/-4 = 0.75 seconds
put into v = 3 - 8t
v = 3 - 8(0.75)
= 3 - 6
= -3 meters/sec. woohoooo! so it's negative 3. you're right it is a 3 but it's a negative 3. cool
it's tough in physics, learning when to not complicate things too much, or learning to realize you're missing certain steps you should do in order to solve a problem! i wonder when i'll learn! i hope i can get good enough with physics to help others someday.
oh check:
0 = 3t - 4t^2
0 = 3(0.75) - 4(0.75)^2
0 = 2.25 - 4(0.5625)
0 = 2.25 - 2.25 = 0 yay!
i declare this problem solved :)
  • · Replies 19 ·
  • · Replies 17 ·
