Finding Volume with Rotational Solids: Cylindrical Shell Method
4 replies · 2K views · last reply
mshiddensecret
The volume of the solid obtained by rotating the region bounded by
x=6y^2 [PLAIN]http://msr02.math.mcgill.ca/webwork2_files/jsMath/fonts/cmmi10/alpha/144/char3B.png y=1 [PLAIN]http://msr02.math.mcgill.ca/webwork2_files/jsMath/fonts/cmmi10/alpha/144/char3B.png x=0[PLAIN]http://msr02.math.mcgill.ca/webwork2_files/jsMath/fonts/cmmi10/alpha/144/char3B.png it is rotate about the y- axis.
Using the disk method, I figured out by integrating (pi)(6y^2)^2 dy from 0 - 1 and got the answer: 22.619
However, I cannot write an integral equation using the cylindrical shell method. My attempt is:
Integrating (2pi)(sqrt(x/6))dx from x = 0 to 6.
[/B]
Check the length of your shells. How long is a shell for some specific x-value? In particular, is it increasing as your approach would suggest?
No! It is not. The whole point of the "shell" method is that the shells are parallel to the axis of revolution. Here, that is parallel to the y-axis.
And if you meant "Isn't it always y?" Again, no it it isn't. x= 6y^2 is the lower boundary, y= 1 is the upper boundary. The length of a shell is the vertical distance between them.
I got it with this:
(2pi)(1-sqrt(x/6))(x)dx
thanks.
