Finding Vout₂ with superposition when current source is replaced with open circuit
  • Thread starter Thread starter Cool hand Jak
    Superposition
1 reply · 2K views
Cool hand Jak
See pdf attachment named Superposition .Find Vout
Steps of Superposition
I fount Vout1 by replacing the voltage source with a short circuit and doing basic d.c. analysis. My answer = 0.85V
However I'm stuck on how to find Vout2. I know you have to replace the current source with an open circuit. This however confuses me as there is now an open circuit in the middle of my circuit and I'm unsure what resistors, if any are in parallel and how to find the voltage across the load which is Vout2
Any help is greatly appreciated.
Thanks
I am not sure which V you are talking about. That network is really confusing to look at.
Could you maybe post your calculations for how you found Vout1 so I can tell where you are coming from?
So, for superposition, you know that you short Vsources and open Isources.
Now, you say that you are confused because there would be an open circuit in the middle of the circuit?
Well, that's not completely true. You would be "opening" the current source, which means you just re-draw the circuit without the current source and perform your analysis again.
Since all you have left is a Vsource, I would recommend using KVL to find all of the currents. That's a hint that you should use KCL to find all of the voltages.
The more I look at the circuit, I wonder why you are using superposition anyway?
