Finding z1 , z2 of complex numer
  • Thread starter Thread starter kelvin macks
    Complex
8 replies · 3K views
kelvin macks
in order to get z1 and z2 , i tried to express z^2 into polar form, but z is to the power of 2, I'm not sure whether it can be epressed in polar form of not. by the way , here's my working. how should i proceed? i don't think my ans is correct.
I can not read your handwriting. The polar form can be used, but the solution is much simpler if you start writing z=u+iv and solving for u, v. Try.
ehild
I can only understand the numbers.
I also find your handwriting unreadable.
ehild
do u mean i should let z = a+bi , then i sub z = a+bi into z^2 ? by doing so, you assume that z1 and z2 , one of it must be conjugate to the others. am i right? here's the sample ans, why the author let z = a-bi , and not z = a+bi ?
I am not ehild, but I really do think that this is what he meant.
can it be done using plar form? if can, can you please show me how do u express z^2 in polar form, i have done it in the very first post, but i don't think it's correct. my ans is weird.
Yeah.
I can, but will not. I like the policy of not giving full answers. For anything.
Hint: do you know De Moivre's formula?
if not, then https://en.wikipedia.org/wiki/De_Moivre's_formula is a good place to start.
There are some other places for it too. The solution you attached in #5 is rock-solid.
Edit: share your attempt at of expressing z^2 using De Moivre's so we can check it for you. Use LaTeX or ASCII characters, you handwriting is... complicated.
No, z1 and z2 are not conjugate pairs, but one is the negative of the other. You can write the complex z as ##z=\pm \sqrt{1-2\sqrt2 i}##
As the imaginary part of z2 is negative, it is convenient to consider the imaginary part of z also negative. It does not matter. So z = a-ib, you square it, and compare with 1-2√2 i, so as the real parts are equal and the imaginary parts are also equal. Solve the system of equation for a, b.
Note that both a and b are real.
You can use polar form, too, but it is tedious. You convert 1-2√2 i to polar form numerically, determine the second roots, and convert back. You round at each step, losing accuracy.
I suspect you did not use the correct formula for the n-th root of a complex number. Check it.
ehild
