Finite Intersection Property Question
The discussion centers on the finite intersection property (F.I.P.) and its implications, particularly in the context of sequences in a field. A formal definition of F.I.P. is sought, emphasizing that if any finite subcollection of closed subsets has a non-empty intersection, then the entire family does as well. The relationship between F.I.P. and the Axiom of Choice is explored, specifically regarding the selection of elements from non-empty sets without additional properties. The conversation also touches on how F.I.P. relates to proving sequential completeness in totally ordered Archimedean fields. Understanding these concepts is crucial for applying F.I.P. in mathematical proofs and discussions.
td88
I'm having a little trouble distinguishing the line between what the f.i.p implies and what it does not.
**EDIT2** Hopefully this will make things more clear
What I'm really interested in is a formal definition of the f.i.p regardless of the set in question or the field.
Given the sequence \{a_n\}_{n \in \mathbb{N}} in some field \mathbb{K}, is having the f.i.p equivalent to saying (\forall n \in \mathbb{N})(\exists x \in \mathbb{K})(x \in \cap_{i=1}^n a_n)
The question about the sequence was that I was afraid (even though it seems pretty clear to me that this should follow from the previous statement) that it's construction assumed that the intersection of the entire set was non-empty as the sequence itself is infinite and says for all n \in \mathbb{N} pick an element from the nth intersection.
My question about the axiom of choice, was that, if I'm just given a sequence of nonempty sets (assuming no other properties like order complete) and I just say form a new sequence by picking some random element from each set in the old sequence, does this require the Axiom of Choice?
Thanks---------------------------------------
Original
Specifically, if we are working in R and \{[a_i, b_i]\}_{i \in \mathbb{N}} satisfies the finite intersection property, then does that imply that (\forall n \in \mathbb{N})(\exists x \in \mathbb{R})(x \in \cap_{i=1}^n [a_i, b_i]), and, if it does, then can we use the axiom of choice (I believe this is needed...) to define a sequence \{c_n\}_{n \in \mathbb{N}} where c_n \in \cap_{i=1}^n [a_i, b_i]?
Thanks
**EDIT** I stated R above to make things simple, but it may help to know that in reality I'm trying to prove that sequential (Cauchy) completeness in a totally ordered Archimedean field implies that every sequence of bounded closed interval with the finite intersection property has a nonempty intersection.
[noparse] Regarding the LaTeX... Start with and end with. Alternatively, use itex instead of tex. itex is supposed to look better if the math expression appears in the middle of a line of text, but it doesn't always. itex also cuts off the top of some large symbols. You can (and should) preview before you post, but there's a bug that makes old latex images show up in all previews except the first. When that happens, just refresh and resend.[/noparse]
Thanks for the LaTeX tip, I changed it
F.I.P. is a property of a space that whenever a family of closed subsets is such that any finite subcollection has a non-empty intersection, so does the entire family.
F.I.P. is related to the Axiom of Choice by Tychonoff's theorem which states that the Cartesian product of compact topological spaces is compact.
http://www.indopedia.org/index.php?title=Tychonoff_theorem
The standard _A " operator" maps a Null Hypothesis Ho into a decision set { Do not reject:=1 and reject :=0}. In this sense ( HA)_A , makes no sense. Since H0, HA aren't exhaustive, can we find an alternative operator, _A' , so that ( H_A)_A' makes sense? Isn't Pearson Neyman related to this? Hope I'm making sense. Edit: I was motivated by a superficial similarity of the idea with double transposition of matrices M, with ## (M^{T})^{T}=M##, and just wanted to see if it made sense to talk...
