Firing a spherical bullet into a watertank
  • Thread starter Thread starter TheMan112
    Bullet Spherical
6 replies · 3K views
TheMan112
[SOLVED] Firing a spherical bullet into a watertank
I've got a problem, involving non-constant acceleration:
If we fire a spherical bullet horizontally into a watertank, how far will the bullet traverse?
I've figured as much that a spherical bullet provides a retarding force:
[tex]F = -k \cdot v[/tex] where k is a constant.
This should provide the following non-constant acceleration due to Newtons 2nd law.
[tex]a = \frac{F}{m} = - {\frac{k v}{m}}[/tex]
I'm thinking I should integrate two times over a(t) to get an expression for x(t), but since "a" is proportional to v(t) and not directly to t, I don't know how to do it without getting a recursive expression.
Hi TheMan112! :smile:
Hint: a = dv/dt. :smile:
You have an equation with separable variables (the form f(y)dy=g(x)dx). This can be solved by integrating both sides: left from y1 to y2, right from x1 to x2.
Another option is solving for v(x):
dv/dx=dv/dt*dt/dx=(dv/dt)/v
After you get v(x) you can get corresponding t from dt=dx/v.
But I don't think that bullets experience linear drag. At high speeds F=-kv^2 is probably a better apoximation.
Alfi said:
Horizontally ?
Or perpendicular to a smooth water surface?
Imagine we mounted the muzzle of a gun to a hole in the side of the watertank, fireing into the water horizontally.
Haha, I know that, and from the following differential equation...
[tex]m\ddot{x}-k\dot{x}=0[/tex]
...I get:
[tex]\frac{dx}{dt} = e^{\frac{m}{k} t}[/tex]
Which in turn gives:
[tex]s = \int_{0}^{\infty} v(t) dt = \int_{0}^{\infty} e^{\frac{m}{k} t} dt = -\frac{m}{k}[/tex]
Which gives an answer wrong by a factor of 10^3.
Somehow you've managed to get a nearly right answer with the wrong reasoning. :rolleyes:
It should be:
[tex]\frac{dx}{dt} = v_0 e^{\frac{-k}{m} t}[/tex]
[tex]s = \int_{0}^{\infty} v(t) dt = v_0 \int_{0}^{\infty} e^{\frac{-k}{m} t} dt\,=\,...\,?[/tex] :smile:
