Firing a spherical bullet into a watertank
  • Thread starter Thread starter TheMan112
    Bullet Spherical
The problem involves analyzing the motion of a spherical bullet fired horizontally into a watertank, focusing on the effects of drag and non-constant acceleration. Participants are exploring the relationship between force, velocity, and acceleration in this context.
  • Participants discuss the integration of acceleration to find position, questioning how to handle the non-constant nature of acceleration due to drag. There are also inquiries about the orientation of the bullet's trajectory and the nature of the drag force acting on the bullet.
Some participants have provided hints and alternative approaches to solving the differential equations involved. There is recognition of the complexity of the drag force, with suggestions that a quadratic drag model may be more appropriate than a linear one. Multiple interpretations of the problem setup are being explored.
There is a mention of a potential misunderstanding regarding the drag force's dependence on velocity, with participants noting discrepancies in the reasoning leading to incorrect results. The discussion is ongoing, with no clear consensus reached yet.
TheMan112
[SOLVED] Firing a spherical bullet into a watertank
I've got a problem, involving non-constant acceleration:
If we fire a spherical bullet horizontally into a watertank, how far will the bullet traverse?
I've figured as much that a spherical bullet provides a retarding force:
[tex]F = -k \cdot v[/tex] where k is a constant.
This should provide the following non-constant acceleration due to Newtons 2nd law.
[tex]a = \frac{F}{m} = - {\frac{k v}{m}}[/tex]
I'm thinking I should integrate two times over a(t) to get an expression for x(t), but since "a" is proportional to v(t) and not directly to t, I don't know how to do it without getting a recursive expression.
Horizontally ?
Or perpendicular to a smooth water surface?
Hi TheMan112! :smile:
Hint: a = dv/dt. :smile:
You have an equation with separable variables (the form f(y)dy=g(x)dx). This can be solved by integrating both sides: left from y1 to y2, right from x1 to x2.
Another option is solving for v(x):
dv/dx=dv/dt*dt/dx=(dv/dt)/v
After you get v(x) you can get corresponding t from dt=dx/v.
But I don't think that bullets experience linear drag. At high speeds F=-kv^2 is probably a better apoximation.
Alfi said:
Horizontally ?
Imagine we mounted the muzzle of a gun to a hole in the side of the watertank, fireing into the water horizontally.
Haha, I know that, and from the following differential equation...
[tex]m\ddot{x}-k\dot{x}=0[/tex]
...I get:
[tex]\frac{dx}{dt} = e^{\frac{m}{k} t}[/tex]
Which in turn gives:
[tex]s = \int_{0}^{\infty} v(t) dt = \int_{0}^{\infty} e^{\frac{m}{k} t} dt = -\frac{m}{k}[/tex]
Which gives an answer wrong by a factor of 10^3.
Somehow you've managed to get a nearly right answer with the wrong reasoning. :rolleyes:
It should be:
[tex]\frac{dx}{dt} = v_0 e^{\frac{-k}{m} t}[/tex]
[tex]s = \int_{0}^{\infty} v(t) dt = v_0 \int_{0}^{\infty} e^{\frac{-k}{m} t} dt\,=\,...\,?[/tex] :smile:
Seems like that did it, thanks!
  • · Replies 16 ·
  • · Replies 31 ·
  • · Replies 24 ·
