First Order Difference Equations
Jill carries out 18 liters of water on the first day, and the amount she carries on subsequent days follows the difference equation An+1=0.96*An+2, starting with A1=18. A participant in the discussion attempts to calculate the total amount of water recycled over the week by manually substituting values into the equation, arriving at a total of 151.16 liters. They inquire about a more efficient method, such as a formula for the sum of the sequence. However, it's noted that for a short time frame like a week, using the difference equation day by day is a valid approach.
diomedes.
Background: Jack's wife Jill, mindful of the water restrictions is determined to carry buckets of bath water out of the house to water bean stalks.
She carries out 18 litres of water on the first day.
The amount of water Jill carries out An, in litres on the nth day is given by the difference equation: An+1=0.96*An+2 , A1=18
Specific: Determine the total amount of water Jill recycles in the first week.
Ok, well I've been working out the answer by finding the total amount recycled each day by manually putting the values into the formula: 1-18 ; 2-19.28 ; 3-20.51 ; 4-21.69 etc and then adding for the total (151.16), but this doesn't seem an efficient way of finding the answer. Is there a formula for the sum (similar to the sums of airthmetic/geometic sequences)?
It is quite possible the answer to this is impossible/obvious, so don't be too harsh :P :)
Have you learned how to solve difference equations? The solution is going to look like A(n)=Crn+D where C and D are constants, so it's the sum of a constant and a geometric progression.
Since A_{n+1}= 0.96 A_n+ 2 is a linear equation, we can add solutions to different parts. In particular, we can look for a solution to the equation A_{n+1}= 0.96 a_n first. Since that involves just repeated multiplication, look for a solution of the form A_n= A_1 r^n for some number r. Then A_{n+1}= A_1r^{n+1} and the equation becomes A_1r^{n+1}= 0.96 A_1r^n. Solve that for r.
Now we could probably find a constant that satifies the entire equation, A_{n+1}= .096 A_n+ 2 by just substituting the constant, A, for both A_{n+1} and A_n. Then add the two solutions.
But, frankly, since this only involves a week, just using the difference equation for each day is a perfectly valid way of solving this problem. You don't have to use a shotgun to kill flies!
Thanks for the advice chaps! Sounds like I'll just have to suck it up and solve for each day :smile: .
  • · Replies 16 ·
18K
