First order in time=> time cannot go backwards ?
  • Thread starter Thread starter pantheid
    First order Time
The discussion centers on the implications of first-order versus second-order time derivatives in partial differential equations (PDEs), particularly in the context of the wave equation and the Schrödinger equation. Second-order equations can yield solutions that allow for time to flow backward, leading to potential violations of causality, while first-order equations typically yield a single solution that aligns with the forward flow of time. The Schrödinger equation is designed as a first-order equation to avoid these backward solutions, incorporating complex numbers for mathematical consistency and physical interpretation. The conversation also touches on the limitations of equations like the heat equation, which cannot derive past states from present conditions due to singularities. Overall, the choice of equation order significantly affects the treatment of time in physical models.
pantheid
First order in time=>"time cannot go backwards"?
I have had numerous professors mention, but not explain, the differences between PDEs that are second order and first order in time. For example, in the regular wave equation, they say that "time can go backwards," or something to that effect. In order to avoid this in the schrodinger equation, it was made first order, but imaginary. Can you guys explain how reducing the order implies that time cannot flow backward (if that is indeed what my professors meant and not a misunderstanding on my part), why this was implemented into the schrodinger equation but not the wave equation, and how this is supposed to be better than complex solutions?
Thanks in advance.
I have zero idea what whoever is saying this is trying to get across. It may have something to do with the derivation of the Dirac equation but I am going to assume its what you say it is, the Schrodinger equation.
But a few points:
1. It's a strange but true fact that the Schrodinger equation can be derived from the Hamilton-Jacobi equation by simply going over to complex numbers:
http://arxiv.org/abs/1204.0653
The link explains why physically - its to do with path cancellation in Feynman's Sum Over History approach.
The deep mathematical reason is you need complex numbers so you can have continuous transformations between so called pure states:
http://www.scottaaronson.com/democritus/lec9.html
http://arxiv.org/pdf/quant-ph/0101012.pdf
2. The real reason for the 'why' of the Schrodinger equation lies in symmetry, as you will find in Chapter 9 of Ballentine - Quantum Mechanics - A Modern Development:
https://www.amazon.com/dp/9810241054/?tag=pfamazon01-20
Thanks
Bill
Equations that depend only on the second power of time (or only on even powers of time in general) are symmetric with respect to time reversal.
Equations that depend only on the first power of time (or only on odd powers of time) are antisymmetric.
Equations that depend both on odd and even powers of time are not symmetric nor antisymmetric.
The problems with symmetric (second-order) equations is that they don't distinguish the time arrow direction. There's no reason for the time to flow forward. Usually there are 2 solutions to such equations, one of which describes processes going forward and one backward in time. The "backward" solution usually violates casuality, which is a bad thing. So physicists say that only one of the solutions is physical and other simply doesn't exist, but that is ugly and arbitrary.
First-order equations on the other hand behave as we expect them to, yielding only one solution that we can assign certain time direction.
There is also a thing called absorber theory that says that the backward solutions actually exist, but are accidentally canceled in our universe.
Perhaps what they are getting at is that in the wave equation, if you know the position and velocity of every point on the wave at a given time ##t##, not only can you derive the shape of the wave at any future time, you can also derive the shape of the wave at any *past* time. Given what the wave looks like now, it is possible to compute what the wave looked like five minutes ago. You do this in exactly the same way you would compute the future shape, except you change a sign somewhere.
This is not possible with all differential equations. For example, for the heat equation
##\frac{d}{dt} \phi = - \nabla^2 \phi##
it is in general *not* possible to derive the past state of ##\phi## from a given present state because you run into singularities when you try to run the equation backwards.
The conclusion is *not* that any equation that is first order in time can't be run backwards. In fact, for the Schrodinger equation,
##i \frac{d}{dt} \psi = - \nabla^2 \psi##
it *is* possible to solve for the past state of ##\psi## given the present state. It is very much like the wave equation in this respect. So I'm not sure why you think the Schrodinger equation can't be run backwards in time.
This sounds interesting. Can you provide some reference illustrating this?
The heat conduction equation is
\frac{\partial T}{\partial t} = \kappa \Delta T
there is partial derivative with respect to ##t## and there is no minus on the right-hand side.
Time reversal invariant Hamiltonians must satisfy ##[H,\Theta]=0## where ##\Theta## is time reversal operator. However, in some texts (for example see Many-body Quantum Theory in Condensed Matter Physics an introduction, HENRIK BRUUS and KARSTEN FLENSBERG, Corrected version: 14 January 2016, section 7.1.4) the time reversal invariant condition is introduced as ##H=H^*##. How these two conditions are identical?
  • · Replies 21 ·
  • · Replies 0 ·
  • · Replies 51 ·
