First Order ODE problem (ipod battery)
The discussion revolves around solving first-order ordinary differential equations (ODEs) related to the battery life of two MP3 players, the aPod and bPod. The aPod's battery life is described by the equation (100 - t²)dA/dt + 4tA = 0, while the bPod's battery life is governed by 100dB/dt - B² + 10000 = 0. The participants analyze the integration techniques required to solve these equations, emphasizing the use of arctanh for the bPod and the need for proper initial conditions. Key conclusions include the necessity of using integrating factors and recognizing the implications of initial conditions on battery life calculations.
  • Understanding of first-order ordinary differential equations (ODEs)
  • Familiarity with integration techniques, particularly arctanh
  • Knowledge of initial value problems in differential equations
  • Ability to manipulate and solve separable differential equations
  • Study the method of integrating factors for solving first-order ODEs
  • Learn about the properties and applications of hyperbolic functions, specifically tanh and arctanh
  • Explore initial value problems and their significance in real-world applications
  • Practice solving separable differential equations with varying initial conditions
Students and educators in mathematics, particularly those focused on differential equations, as well as engineers and scientists analyzing battery life and performance in electronic devices.
Clef
Cappy McGreenhorn is looking to buy a new MP3 player. His primary concern is the
battery life of the MP3 player. He has decided on either the aPod or the bPod. The
percentage of battery life A(t) (after t hours) for the aPod is governed by:
(100 - t2)dA/dt + 4tA = 0; with A(0) = 100:
The percentage of battery life B(t) (after t hours) for the bPod is governed by:
100dB/dt - B2 + 10000 = 0; with B(0) = 100 tanh(12):
(a) Which MP3 player should Cappy buy in order to get the longest playback time?
(b) What is the battery charge on the bPod at t = 6?
(c) When does the aPod hold a 50% battery charge?
HINT: Do not use partial fractions to do the integration. Use the fact that:
d/dx(arctanh(x)) =1/(1 - x2)
I worked out Apod to be (1/100) (100-t2)2
But I think this is wrong.
The second part I used separable vales and ended up with
B= 100tanh(1/100 (t + 12))
However, I know that my second solution must be wrong since you cannot have negative
time and when the battery = 0, my time will be -12 hours. :(
Is it possible to use integrating factors to do the first order ode problem for bpod?
Also for my hours i got 10 and 12 hours respectively. But I am still unsure about the Bpod :'(
I have been trying to solve the Bpod but I can't seem to get it. That has to be the strangest initial condition I have ever seen. (For a textbook problem.) Obviously it is simply 100 because the tanh(12) is 1. (Assuming radians are being used.)
Thanks
Matt
So dA/A= 4tdt/(100- t2). Let t= 100- t2 on the right and integrate
Is that "B2" supposed to be B2? If so the equation is not linear and you cannot find the "integrating factor".
100dB/(10000- B2)= -dt
Good hint! So that was B2. Let u= B/100 so that 10000- B2= 10000- 10000u2= 10000(1- u2) and du= 100dB. Your equation becomes (1/10000)du/(1- u^2)= -dt or du/(1- u^2)= -10000 dt. Did you miss the negative here? As the hint tells you that integrates to arctanh(u)= arctanh(B/100)= -10000t+ C.3 Now, at t=0, you have arctanh(tanh(12)= C or C= 12.
Let t=100-t^2? I tried doing this but I couldn't make sense of it... how would I integrate it?
Also, thanks so much for posting your help.
I meant, of course, "let u= 100- t2". Then du= -2t dt so t dt=-(1/2)du. The equation becomes dA/A= -2du/u. That should be easy to integrate.
12K
  • · Replies 56 ·
54K
21K
