Fixing hazards in a logic expression
  • Thread starter Thread starter STEMucator
    Expression Logic
5 replies · 2K views
Identify and fix all hazards in ##f = (ab + \bar{a}c)(c + \bar{b}) + ab##. Re-check if the final expression obtained is hazard free.
So I used a binary tree and found a static 1 hazard present for ##bc = 11##. The hazard was ##a + \bar{a}##.
To fix this hazard, I need a ##\sum## of ##\Pi## map using ##f##.
I am confused about the term ##(ab + \bar{a}c)(c + \bar{b})##. I don't know how to place it on a K-Map.
I know I can't use the distributive laws because that will introduce dynamic hazards since ##b## and ##\bar{b}## are together.
How would I go about creating the K-Map exactly?
mfb said:
As you have "+ab" at the end, do you need the "ab" in the first bracket at all?
I would think I do need it. I can't just remove it can I? The first term is an AND term, so I don't have a term of the form ##ab + ab##.
"((X OR Y) AND Z) OR X" = "(X AND Z) OR (Y AND Z) OR X"
But "(X AND Z) OR X" is just X.
Alternatively, just test all 8 options to verify it.
Okay, so I can use distributivity and simplification as long as I'm particularly careful about ##b## and ##\bar{b}##:
$$(ab + \bar{a}c)(c + \bar{b}) + ab$$
$$ab(c + \bar{b}) + \bar{a}c(c + \bar{b}) + ab$$
$$ab(c + \bar{b}) + ab + \bar{a}c(c + \bar{b})$$
$$ab + \bar{a}c(c + \bar{b})$$
It's safe to use distributivity now:
$$ab + \bar{a}cc + \bar{a}c \bar{b}$$
$$ab + \bar{a}c + \bar{a}c \bar{b}$$
$$ab + \bar{a}c$$
Drawing the K-Map:
ab\c
0 1
0 1
1 1
0 0
I see I need a term of the form ##bc## to fill the valley. Hence:
$$f = ab + \bar{a}c + bc$$
This expression is hazard free.
