Fixing VHDL Errors for Traffic Light System
1 reply · 3K views
JOZ
Hi I've got a problem with VHDL code its coming up with a lot of errors saing that there's undefined symbols, so I am pretty sure that the error is to do with defining things/instantiation, below is all the code for both the files that are being used
Code:
--  Traffic.vhd
-- Traffic light system to control an intersection
-- Skeleton - Add your comments here!
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity Traffic is
   Port ( Reset      : in   STD_LOGIC;
          Clock      : in   STD_LOGIC;
          -- for debug
          debugLED   : out  std_logic;
          -- Car and pedestrian buttons
          CarEW              : in   STD_LOGIC; -- Car on EW road
          CarNS              : in   STD_LOGIC; -- Car on NS road
          PedEW              : in   STD_LOGIC; -- Pedestrian moving EW (crossing NS road)
          PedNS              : in   STD_LOGIC; -- Pedestrian moving NS (crossing EW road)
          -- Light control
          LightsEW           : out STD_LOGIC_VECTOR (1 downto 0); -- controls EW lights
          LightsNS           : out STD_LOGIC_VECTOR (1 downto 0)  -- controls NS lights
end Traffic;
architecture Behavioral of Traffic is
  -- Encoding for lights
  constant RED   : std_logic_vector(1 downto 0) := "00";
  constant AMBER : std_logic_vector(1 downto 0) := "01";
  constant GREEN : std_logic_vector(1 downto 0) := "10";
  constant WALK  : std_logic_vector(1 downto 0) := "11";Component Timer
  Port ( clr : in  STD_LOGIC;
         clock : in  STD_LOGIC;
         globalReset : in  STD_LOGIC;
         load : in  STD_LOGIC;
         Sec5 : out  STD_LOGIC;
         Sec2 : out  STD_LOGIC;
         Sec1 : out  STD_LOGIC);
end Component;
Begin
T1 : Timer PORT MAP (
    clr => clr,
    clock => clock,
    globalReset => globalReset,
    load => load,
    Sec5 => Sec5,
    Sec2 => Sec2,
    Sec1 => sec1,
   type StateType is (GreenRed, AmberRed, RedGreen, RedAmber, WalkRed, RedWalk, RedGed, GedRed);
signal state, nextstate : StateType;
HPedEW            :STD_LOGIC; -- Hold value of PedEW
HPedNS            :STD_LOGIC; -- Hold value of PedNS
  debugLed <= reset; -- Show reset status on FPGA LED
  LightsEW <= RED;
  LightsNS <= GREEN;
----process which changes to the next state on the clock edge
ChangeState:
process(globalReset, Clock)
begin
    if (globalReset = '1') then
        state <= GreenRed;
    elsif rising_edge(clock) then
        if(HPedNS='0') then
            HPedNS<=PedNS;
        end if;
        if(HPedEW='0') then
            HPedEW<=PedEW;
        end if;
        state <= nextstate;
    end if;
end process ChangeState;-----state machine which chooses what the next state will be
StateMachine:
Process(state, CarEW, CarNS, HPedEW, HPedNS, Sec1, Sec2, Sec5)
begin
 -- default state is GreenRed
    case state is
        when GreenRed =>
        LightsNS <= GREEN;
        LightsEW <= RED;
            if ((HPedEW = '1') or (CarEW = '1')) and (Sec5='1')  then
                resetCount;
                nextstate <= AmberRed;
            elsif (HPedNS = '1') and ((Sec2='0') or ((HPedEW = '0') and (CarEW = '0')) then
                loadCount<=’1’;
                nextstate <= WalkRed;
            end if;        when WalkRed =>
        LightsNS <= WALK;
        LightsEW <= RED;
loadCount<=’0’;
            if(Sec5='1') then
                resetCount;
                nextstate <= GreenRed;
                HPedNS<='0';
            end if;        when AmberRed =>
        LightsNS <= AMBER;
        LightsEW <= RED;
            if(Sec1='1') then
                resetCount;
                nextsate<=RedGed
            end if;
        when RedGed =>
        LightsNS <= RED;
        LightsEW <= RED;
            if(Sec1='1') then
                resetCount;
                if (HPedEW = '1') then
                    loadCount<=’1’;
                    nextstate <= RedWalk;
                else
                    nextstate <= RedGreen;
                end if;
            end if;
        when RedGreen =>
        LightsNS <= RED;
        LightsEW <= GREEN;
            if ((HPedNS = '1') or (CarNS = '1')) and (Sec5='1')  then
                resetCount;
                nextstate <= RedAmber;
            elsif (HPedEW = '1') and ((Sec2='0') or ((HPedNS = '0') and (CarNS = '0')) then
                loadCount<=’1’;
            end if;        when RedWalk =>
        LightsNS <= RED;
        LightsEW <= WALK;
        loadCount<=’0’;
            if (Sec5='1') then
                resetCount;
                HPedEW <='0';
            end if;
        when RedAmber =>
        LightsNS <= RED;
        LightsEW <= AMBER;
            if(Sec1='1') then
                resetCount;
                nextstate<=GedRed
            end if;
        when GedRed =>
        LightsNS <= RED;
        LightsEW <= RED;
            if(Sec1='1') then
                resetCount;
                if (HPedNS = '1') then
                    loadCount<=’1’;
                else
                end if;
            end if;       end case;
end process StateMachine;end;
The other files is:
Code:
-- timer module
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;entity Timer is
end Timer;
architecture Behavioral of Timer is
signal count : natural range 0 to 501;
beginprocess(globalReset, clock) is
begin
   if globalReset = '1' then
     count <= 0;
   elsif (count <= 500)  and (rising_edge(clock)) then
     if clr = '1' then
    count <= 0;
     elsif load = '1' then
       count <= 200;
    load <= '0';
     else
       count <= count + 1;
     end if;
   end if;    if count >= 100 then Sec1 <= '1';
        else Sec1 <= '0';
    end if;
    if count >= 500 then Sec5 <= '1';
        else Sec5 <= '0';
    end if;
    if count >= 200 then Sec2 <= '1';
        else Sec2 <= '0';
    end if;
end process;
end Behavioral;
There seems to be missing signals in the top unit which connects to the signals from the component Timer
