Flow as a fluid-orthogonal foliation
  • Level: Graduate
  • Thread starter Apashanka
    Flow
11 replies · 2K views · last reply
Apashanka
If considering the 4-D manifold(##x^1,x^2,x^3,t##) in which the sub-manifold dimensionality is 3(##x^1,x^2,x^3##)(hypersurface)
We are writting the metric of this space as ##ds^2=g(t)dt^2+f(t)\gamma_{ij}{dx^idx^j}\delta_{ij}## where the term ##\gamma_{ij}dx^idx^j\delta_{ij}## is the metric of the hypersurface assuming that ##\frac{∂}{∂t}=\hat t## is orthogonal to the hypersurface .
A very elementary rough diagram is this
Hand-drawn diagram of a 3D slice in spacetime: vertical axis labelled t, a tilted parallelogram plane with a right-angle marker at the origin labelled (b), an arrow labelled u pointing up from the plane marked Rest frame, and the coordinates (x1, x2, x3) labelling the plane, with the handwritten caption Submanifold Hypersurface.
Now from the four velocity ##V^\mu=\gamma##{c,##v_{spatial}##}
If a particle is at rest in one frame then it's ##V^\mu## points along ##\hat t## (perpendicular to the hypersurface) and if it is having some spatial velocity in another frame then the velocity four vector ##V^\mu## is now tilted at an angle to the hypersurface(e.g roughly we can say there are two components ,along ##\hat t## and ##V_{hypersurface})##
Till now it's ok but these lines from a paper I am unable to understand and connects ,to the above
Screenshot of a page of LaTeX-typeset academic text on spatial foliations and fluid 4-velocity projectors, including the equations h_μν = g_μν + n_μ n_ν and b_μν = g_μν + u_μ u_ν, with a footnote 5.
From ''Accordingly .....to ##b_{\mu \nu}##'' here ##n## is along ##\hat t## and ##u## is the four velocity.
Can anyone help me in sort out this
  • Hand-drawn diagram of a 3D slice in spacetime: vertical axis labelled t, a tilted parallelogram plane with a right-angle marker at the origin labelled (b), an arrow labelled u pointing up from the plane marked Rest frame, and the coordinates (x1, x2, x3) labelling the plane, with the handwritten caption Submanifold Hypersurface.
  • Screenshot of a page of LaTeX-typeset academic text on spatial foliations and fluid 4-velocity projectors, including the equations h_μν = g_μν + n_μ n_ν and b_μν = g_μν + u_μ u_ν, with a footnote 5.
A very elementary rough diagram is this View attachment 239632
Till now it's ok but these lines from a paper I am unable to understand and connects ,to the aboveView attachment 239633
Can anyone please help me...
What exactly is the question? In that sentence there are no computations or any arguments/reasoning to explain. They only introduce the standard notations and names for the projections.
I didnt understand the projections they're taking about??
If you don't understand the general concept of projections, then the paper you referenced is probably too advanced for you. And trying to explain that concept from scratch is probably too much for a PF thread.
What textbooks on differential geometry have you studied? Projections are a basic concept of differential geometry. You really need to have a good understanding of differential geometry before trying to work through a paper like the one you linked to.
The basic idea is that, if you have a timelike vector at a given event, then the metric of a local spacelike hypersurface orthogonal to that timelike vector at that event is given by the formulas in what you quoted. The formulas are given for two different choices of timelike vector: ##n##, the vector that points along the timelike lines of the chosen foliation, and ##u##, the vector that points along the fluid flow lines.
Going into much more detail than that is probably, as I said before, beyond the scope of a PF thread.
Sir one question, space like vectors can't be along ##\hat t## ,isn't it??they are outside the light cones
Thread closed as the subject matter is "A" level and the OP does not appear to have the required background.
@Apashanka, based on your repeated threads on subjects related to this one, it really appears that you need to spend some time developing your understanding of differential geometry and how it is used in General Relativity. Here at PF we can help with specific questions, but we are not equipped to give a complete graduate level course in differential geometry and GR, and it's difficult to answer questions that require that background knowledge if the person asking them does not have it.
