Flow rate across line AB using source potential function
4 replies · 2K views · last reply
tracker890 Source h
Determine flow rate per unite width in the line
flow rate equation
Q:Please hlep me to understand which ans is correct.To determine the flow rate in Line AB.
$$\mathrm{Known}:V_A,q,r_A = constant.$$
Diagram of a source flow with a source at the origin, labeled q, on x and y axes. Point A is at (1, 1) and point B is at (-1, 0.5), joined by a blue line, with dashed guides showing 1 m horizontal and 0.5 m vertical offsets.
so/
select:## A,{B}^{\text{'}},B,A,## is control volume
Diagram of a source flow with a red circle centred at the origin; points A at (1, 1) and B at (-1, 0.5) are joined by a blue line, with rays psi_A and psi_B from the origin, angles theta_A and theta_B marked, and 1 m and 0.5 m dimension arrows.
$${Q}_{AB}={Q}_{A{B}^{\text{'}}}=\iint _{A}^{}({V}_{A})dA={\int }_{{\theta }_{A}}^{{\theta }_{B}}({V}_{A}){r}_{A}d\theta $$$$\overset\rightharpoonup{V}=\triangledown \phi =<\frac{\partial \phi }{\partial r},\frac{1}{r}\frac{\partial \phi }{\partial \theta }>=<\frac{1}{r}\frac{\partial \psi }{\partial \theta },-\frac{\partial \psi }{\partial r}>=<{V}_{r},{V}_{\theta }> $$$$\therefore V_A=\frac1{r_A}\frac{\partial\psi}{\partial\theta}\;$$$$Q_{AB}=\int_{\theta_A}^{\theta_B}{(V_A)}r_Ad\theta\;=\;\int_{\theta_A}^{\theta_B}{(\frac1{r_A}\frac{\partial\psi}{\partial\theta})}r_Ad\theta=\int_{\theta_A}^{\theta_B}{(\frac{\partial\psi}{\partial\theta})}d\theta=\psi_B-\psi_A$$to find ##\psi##,
$$F(z)=\frac q{2\pi}\ln(z)=\frac q{2\pi}ln(re^{i\theta})=\frac q{2\pi}\ln r+i\frac q{2\pi}\theta=\phi+i\psi$$so $$\psi=\frac q{2\pi}\theta$$
$$Q_{AB}=\psi\left(\theta_B\right)\mathit-\psi\left(\theta_A\right)\mathit=\frac q{2\pi}(\theta_B-\theta_A)$$$$\theta_A=\tan^{-1}\left(\frac11\right)=0.7854\;rad,$$
$$\theta_B=\frac\pi2+\tan^{-1}\left(\frac1{0.5}\right)=2.6779\;rad$$
So ans by myself is
$$\therefore Q_{AB}=\frac q{2\pi}{(2.6779-0.7854)}=0.3012q............(Ans(1))$$$$////////////////////////$$
But book say:
$$\theta_A=\tan^{-1}\left(\frac yx\right)=\tan^{-1}\left(\frac{\mathit1}{\mathit1}\right)=0.7854\;rad$$$$\theta_B=\tan^{-1}\left(\frac yx\right)=\tan^{-1}\left(\frac{0.5}{-1}\right)\;=\;-0.4636\;rad$$$$Q_{AB}=\psi\left(\theta_A\right)-\psi\left(\theta_B\right)=\frac q{2\pi}{(0.7854+0.4636)}=0.19878q........(Ans(2))$$
You may have noticed that the two values for θB differ by π.
The result of arctan is of course multi-valued, with the values at intervals of π. So it is always necessary to make sure that the right value is selected. Question is, which of you selected the right value? (I'm with you.)
I think the flow rate in book is ## {Q}_{A{B}^{*}} ## not ## {Q}_{A{B}^{\text{'}}}##.
So the book answer is not correct.
Am I right ?
Diagram of a circle centred at the origin with a source at the origin, points A at (1, 1) and B at (-1, 0.5) joined by a blue line, the reflections B' and B* on the circle, and angles θA and -θB marked from the x-axis.
Am I right ?
I think so.
