Fluid Displacement and the Drop in Water Level Explained
When the anchor is in the boat, it displaces a volume of water equal to its weight, causing the water level to rise. Once the anchor is dropped into the pool, it displaces a volume of water equal to its own volume, which is less than the volume displaced when it was in the boat due to its higher density. This results in a net decrease in the water level. The confusion arises from the difference between weight displacement and volume displacement. Ultimately, the water level drops because the anchor displaces less water when submerged than when it was in the boat.
vu10758
A small child floats in a boat in a swimming pool. The boat contains an anchor
The child drops the metal anchor into the water and watches it sink to the bottom. Meanwhile, the water level in the pool (measured by its height on the side of the pool) actually drops. Why?
I am thinking that if the anchor is dropped into the water, the water should rise because of Archimedes principle. However, I am told that the water level actually drop. Where did the water go? Is it because as the boat pushes down on the water, the water pushes the boat further up due to Newton's third law, causing it to appear as if the water level has dropped? Or is the reason something else? I know that the change in pressure is the same as the weight of the boat so does this have anything to do with the question?
Think about the mass of the anchor and its volume. When the anchor is in the water what volume of water does it displace? When the anchor is in the boat what volume of water does it displace?
11K
11K
