Fluid dynamics vs Electrodynamics
The discussion centers on the choice between electrodynamics and fluid dynamics, with participants emphasizing that the decision largely depends on individual academic and career goals. Mechanical and aerospace engineers typically favor fluid dynamics due to its relevance in their fields, while electrical engineers lean towards electrodynamics, especially those focused on electronics. Some participants express a preference for fluid dynamics due to its intuitive nature, despite acknowledging the complexity of its mathematics. Others find electrodynamics more challenging, particularly if they lack a strong mathematical foundation. The importance of the instructor's competence and personal interest in the subject matter is highlighted as crucial factors in making the choice. Additionally, there is a recognition that both subjects share foundational principles, and a solid understanding of one can aid in grasping the other. Overall, the discussion reflects a nuanced consideration of how personal interests and career aspirations influence the selection between these two areas of study.
Which subject?
  • Fluid Dynamics
    Votes: 11 42.3%
  • Electrodynamics
    Votes: 15 57.7%
  • Total voters
pivoxa15
If you could only do one which one would you choose? And why?
Electrodynamics. Its more in line with what I'm doing.
fluid dyanamics. Its more in line with what I'm doing.
geeez i don't even know what they teach in electrodyanamics
Obviously, no can answer that without understanding in what context the question is asked.
yes i agree. there are lots and lots of conditions affecting one's choice
I'd do both. I don't like arbitrary choices.
Why would one have to choose one or the other.
A mechanical or aerospace engineer would choose fluid dynamics since that is part of MechE or AeroE.
A physicist would choose either depending on interest. A plasma physicist would probably do both.
A EE would choose electrodynamics. Someone interested in electronics or electrical engineering would find electrodynamics of more use than fluid dynamics.
i am doing fluid dynamics actually
for straight-up physics, electrodynamics.
seems like fluid mechanics has been phased out of the american physics undergrad curriculum, so you won't be seen as deficient for not having taken it.
now, if you're in engineering, that's a different ball game.
I've heard they use the same maths but fluid mechanics would be more intuitive so might be better to do it prior to electrodynamics. But the problem is on the appearance of it, it seems so boring which is not a good thing to say but that how I feel. I can only fit one of the two though.
If I had to choose, electrodynamics. The physical processes behind fluid dynamics, while evidently complicated, are intuitive - the only challenge is familiarity with the mathematics. Electrodynamics is likely to involve a lot more head-scratching. I'd much rather brush up on fluid dynamics by myself later on than electrodynamics, which I'd much rather be taught by someone competent.
I had to take both. I picked fluids just because it applies more the the fields I am interested in, Heat transfer and aerodynamics.
Stay away from fluid mechanics and take Aerodynamics using Andersons book. There are a ton of Junk Fluid Mechanics books out there.
How would you compare against the two? Which was harder to learn?
I found the electrical classes harder because when i started them I hadn't even gotten to multivariable calc and it didn't get a good grip of the fundamental E&M derivations. Fluids was easier because by then I had finished all my undergrad math requirements, and the calculations were not so challenging.
The decision should come down to two things. Who's the professor, and which one do you have more interest in. If you take the class with someone who is competent in the field, and who you can follow their lecture you should do well in either. However, you need to evaluate your overall career goal as to what field you want to specialize in.
Not sure what point in your academic career you are at, but I hope that helped.
Continuum modeling is Continuum modeling. The physics is different, but ALL the governing equations are based on fields. If you understand the general field equations you can do both. Simple things to keep in mind: a gradient of a scaler is a vector no matter which area you do, and most importantly: momentum, mass, charge, and energy always balance.
Modey3
