Flywheel with kinetic friction
The discussion revolves around calculating the average magnitude of the couple due to kinetic friction in a flywheel, which requires 1500 revolutions to coast to rest from 3000 rpm. The initial kinetic energy was calculated using the radius of gyration and mass, resulting in a value of approximately 2.72 million joules. The work-energy principle was applied, leading to an initial miscalculation of the frictional couple, which was later corrected by using the appropriate conversion for mass in the Imperial system. The importance of using slugs for mass and pounds for weight in calculations was emphasized to avoid errors. Ultimately, the correct couple due to kinetic friction was determined to be 87.8 lb·ft.
JJBladester
It is known that 1500 revolutions are required for the 6000-lb flywheel to coast to rest from an angular velocity of 3000 rpm. Knowing that the radius of gyration of the flywheel is 36 in., determine the average magnitude of the couple due to kinetic friction in the bearings.
Answer:
\left |M \right |=87.8lb\cdot ft
KE_1+Work=KE_2
Work_{1\rightarrow 2}=M\theta
It takes 1500 revolutions to come to rest and 1 revolution = 2\pi, so 1500 revolutions = 3000\pi.
W = 600lbs
m=\frac{W}{g}=\frac{6000}{9.81}=612lbs
\omega _1=300\frac{rev}{min}*\frac{2\pi}{1rev}*\frac{1min}{60sec}=10\pi\frac{rad}{sec}
Radius of gyration (k) = 36 in = 3 ft
KE_1=\frac{1}{2}\bar{I}\omega_1^{2}=\frac{1}{2}\left (k^2m \right )\omega_1^{2}=\frac{1}{2}\left (3^2*612 \right )\left (10\pi \right )^{2}=2.72e^6J
Work_{1\rightarrow 2}=M\theta=M(3000\pi)
KE_1+Work=0
2.72e^6=\left (-3000\pi \right )M
M=-288.6lb\cdot ft
I'm off... but where?
When using weight in pounds, you must divide by g in units of ft/sec^2 in order to get the mass in slugs
It's also customary to write lbf for weight and lb for mass (slugs). Aside from units do you see where my method is incorrect? Thanks in advance Phantom. Happy Thanksgiving.
Thank you, same to you.
Your method is fine, but when using the Imperial System of measure, always always always, in Physics, express force units in pounds and mass units in slugs. 1 slug weighs 32.2 pounds on Planet Earth (W = mg), and a force of 1 pound will give amass of 1 slug an acceleration of 1 m/s^2. Any other system of units, if youare not using SI, will lead you astray, guaranteed.
PhanthomJay said:
32.2 pounds
... Yeaaaaa, I used 9.81. Now the math works out. As a certain TV character would say, "DOH!"
