Focal Length - please check my work and tell me what's wrong.
The discussion centers on a two-lens optical system involving a diverging lens and a converging lens. The converging lens has a focal length of 11.4 cm, and the calculations for the object distance and image distance were initially incorrect due to a misinterpretation of the focal length as 12 cm instead of 11.4 cm. The correct focal length of the diverging lens was calculated to be -19.0 cm, confirming that focal lengths for diverging lenses are negative by definition. The final image distance was found to be -5.6 cm, which indicates an error in interpretation since distances cannot be negative.
  • Understanding of lens formulas, specifically 1/f = 1/o + 1/i
  • Knowledge of the properties of converging and diverging lenses
  • Familiarity with the concept of real and virtual images in optics
  • Basic algebra skills for solving equations
  • Review the lens formula and its application in optical systems
  • Study the characteristics of real and virtual images formed by lenses
  • Learn about the sign conventions for lens focal lengths
  • Explore more complex lens systems, including combinations of multiple lenses
Students studying optics, physics educators, and anyone involved in optical system design or analysis will benefit from this discussion.
vucollegeguy
A small object is 25.0 cm from a diverging lens as shown in the figure . A converging lens with a focal length of 11.4 cm is 30.0cm to the right of the diverging lens. The two-lens system forms a real inverted image 17.0 cm to the right of the converging lens.
1/f = 1/o + 1/i at every step
conv lens
1/12 = 1/o + 1/17.0
o = 40.8
This means the second object, which is the first image, was 40.8 cm to the left of the conv lens.
This means the second object was 40.8 - 30 = 10.8 cm to the left of the div lens
So the image distance for the div lens is -10.8 and
1/f = 1/25.0 + 1/(-10.8)
1/f = 0.04 - 0.0926 = -0.05259
f = -19.0 cm is the focal length of the div lens
Hello vucollegeguy,
conv lens
1/12 = 1/o + 1/17.0
o = 40.8
Where do you get a length of 12 cm? :rolleyes: The problem statement says that the converging lens has a focal length of 11.4 cm. You might want to correct this before you move on. 'Turns out it makes a significant difference in the end.
I changed 12 to 11.4. My final answer came out to be -5.6 but distance can't be negative. Is my answer correct?
Correct me if I'm wrong, but I thought you were solving for the focal length of the diverging lens. Focal lengths of diverging lenses are negative by definition.
