For M a 4-mfld., every class in H_2(M;Z) can be represented by a Surface.
  • Context: Graduate
  • Thread starter Thread starter Bacle
    Class Surface
For a 4-manifold M, every class in H_2(M;Z) can be represented by a surface S, with an embedding i of S into M such that [i_*S]_2 = [a]_2. If M is simply-connected, Pi_2(M) is isomorphic to H_2(M;Z), allowing representation as embedded spheres. In cases where M is not simply-connected, the discussion suggests using Poincaré duality and transversality theory to construct embeddings. The conversation highlights that any homology class can be represented by an immersed sphere, and isotopy is a relevant concept for studying embeddings.
  • Understanding of 4-manifolds and their properties
  • Familiarity with homology and cohomology, specifically H_2(M;Z)
  • Knowledge of Poincaré duality and its applications
  • Basic concepts of transversality theory in differential topology
  • Study the implications of Poincaré duality in algebraic topology
  • Learn about transversality theory and its applications in embedding problems
  • Explore isotopy and its role in the classification of embeddings
  • Investigate the representation of homology classes in higher dimensions, particularly in dimensions six and seven
Mathematicians, topologists, and researchers in differential geometry focusing on the representation of homology classes and embeddings in 4-manifolds.
Bacle
Hi, I am trying to show that for M a 4-manifold,
and [a]_2 a class in H_2(M,Z) , there is always
a surface that represents [a]_2 , i.e., there
exists a surface S , and an embedding i of S into
M , with [ioS]_2 =[a]_2.
(Equiv.: there exists S, and an embedding i of S of M , so that a triangulation of S
induces the class [a]_2)
** What I have **
If M is simply-connected, so that Pi_1(M)=0
(Notation: Pi_1:=Fund. Grp.)
Then, by the Hurewicz Theorem (Hip, Hip Hurewicz!)
Pi_2(M) is actually Isomorphic to H_2(M;Z) , so that
every class in H_2(M;Z) can be represented as an
embedded sphere S^2 (possibly with self-intersections,
which can be smoothed away ).
**BUT** I can't think of what can be done if
M is not simply-connected.
Any Ideas.?
Why can you smooth self-intersections? If I'm not wrong, this is precisely the reason why h-cobordism fails in 4 dimensions.
Here's an idea that works if your manifold has no two-torsion (also covers the simply connected case). Take a class, and take the poincare dual. Then identify the poincare dual with a line bundle whose generic section intersects the zero section in an embedded surface homologous to what you started with.
how do you know that the map of the 2 sphere has no critical points?
Maps from the two-sphere into a four-dimensional manifold are generically immersions, but not embeddings. There's no way to ensure that a given map from the two-sphere can be perturbed to be an embedding.
I can construct ugly maps of the 2 sphere into R^4 that are not immersions. Are you saying that any such map is smoothly homotopic to an immersion?
Yes.
zhentil said:
Yes.
How does the proof go?
It's standard transversality theory. I guess a good reference is Hirsch.
But I guess in this case, you don't need any fancy stuff ;)
In your case, I would even go so far as to say that your ugly map is homotopic to the standard embedding of S^2 into R^4.
what is a non-fancy proof?
That R^4 is contractible :)
right. So actually any homology class can be represented by an immersed sphere.
I wonder what sort of equivalence classes of immersed manifolds you get if you require the homotopies to be immersions for each time. So immersed M is equivalent to immersed N if they can be moved into each other through a 1 parameter family of immersions.
Well again, in the case of R^4, there's not too much homology to worry about.
The second question is quite interesting. You might want to look into isotopy, which is the relevant idea in the case of embeddings. I'm not sure how much work has been done in terms of using isotopies to study homology. I can tell you this: if you go up to dimension six, you can guarantee that two-homology can be represented by embedded surfaces, and two homotopic embeddings are homotopic through immersions. If you go to dimension seven or higher, it would be through embeddings.
these seem like wonderful theorems. reference or can you explain them? Are you referring to 2 dimensional homology classes only?
  • · Replies 20 ·
  • · Replies 93 ·
15K
  • · Replies 56 ·
11K
  • · Replies 16 ·
  • · Replies 175 ·
27K
  • Poll Poll
  • · Replies 35 ·
29K
