Force between blocks in a line with 14 N push
12 replies · 3K views · last reply
farrah003
Blocks of mass 5, 10, and 25 kg are lined up from left to right in that order on a frictionless surface so each block is touching the next one. A rightward-pointing force of magnitude 14 N is applied to the left-most block.
[a] What is the magnitude of the force that the middle block exerts on the rightmost one?
What is the magnitude of the force that the leftmost block exerts on the middle one?
[c] Suppose now that the left-right order of the blocks is reversed. Now find the magnitude of the force that the leftmost block exerts on the middle one?
this is what i tried doing but i think I am totally off
Fm3m2 = m2a + 14 - m1a
  • Diagram of three green blocks of increasing height side by side on a horizontal surface, with a horizontal arrow labeled Force pointing right into the leftmost, smallest block.
Welcome to PF!
Hi farrah003! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
They all have the same acceleration, so use F = ma on all-three-together to find a.
Then use F =ma (with that a) on individual blocks. :wink:
i tried f = ma
this is what i did
m = 5+10+25 = 40
14 = 40(a)
a = .35
but it said that's not the right answer
sorryy my mistake i got it for part a which was 8.75 but when i did it again for part b it said wrong
That F is the total force.
Apart from the right-most block (which you solved for in part a), each block has two forces on it.
so then i do 14=5a
then the a is 2.8 n if i multiply that I am going to get 14 again ... I am confused !:confused:
farrah003 said:
so then i do 14=5a
No, a is the same for all three blocks.
The left block has two forces on it: 14 from the left, and the reaction force from the right.
The vector sum of those two forces is 5a.
lol i still don't know what numbers to use in what formula
(just got up :zzz: …)
The left block has two forces, 14 and R (the reaction force from the middle block), so F = ma means 14 - R = ma.
