Force between particles in nucleus
The discussion focuses on calculating the minimum repulsive electrostatic force between two protons in the nucleus of a zinc atom, which contains 30 protons and 35 neutrons. The user initially struggles with determining the maximum distance between the protons and considers using the formula for electrostatic force. Clarification arises that the problem only requires the force between the two specified protons, regardless of the influence of other protons in the nucleus. The user realizes that the repulsive force can be calculated without considering the interactions from additional protons. The conversation emphasizes understanding the parameters of the problem to find the solution effectively.
tomwilliam
The nucleus of a zinc atom has 30 protons and 35 neutrons, and a diameter of 4.00 x 10^-13 m.
What is the minimum repulsive electrostatic force between two protons in the nucleus.
Not sure how to approach this. I understand that the minimum force will be when these protons are furthest apart. How do I calculate the maximum distance between the protons in the nucleus?
Using Electrostatic Force = -DeltaPotentialEnergy/distance?
I can calculate the spherical area of the nucleus, and calculate the number density of the protons, but I don't see how this helps. I could use ElectricalPotentialEnegy = q1q2/(4pi perm0 r) and use the known charge of a proton, but I still have two unknowns (r and Potential Energy).
Any ideas?
Thanks
You seem to be overthinking this problem.
Imagine two particles are confined to be within a sphere of diameter D. How far apart can the two particles get?
Well, I see what you're saying for two particles. But if two protons in the zinc nucleus experience a repulsive force as a result of being at either end (maximum distance apart), then what about the repulsive force as a result of all of the other protons? How can I just ignore that?
Forget it - I've just realized that the question is only asking for the force between the two protons in question...
Thanks for your help.
