- 29,820
- 21,646
... like the first postulate?Dale said:Then the next thing to focus on is basic special relativity ...
I don't think that was part of my study somewhere.Dale said:Do you understand Lagrangian mechanics?
The acceleration measured by an accelerometer attached to the object.HansH said:What do you mean by 'proper accelleration'
Yes.HansH said:When i am in freefall does that mean my proper accelleration is zero?
If you want something useful, nothing you can study in relativity will be more useful than learning Lagrangian mechanics. And when you do learn the Lagrangian approach it will eventually make studying non-inertial reference frames easier. However, it isn't as "exciting" a topic as relativity.HansH said:I don't think that was part of my study somewhere.
ok that helps. Then it means that I am not referring to the tem ''proper acceleration' but to the accelleration as result of an applied force such as a rocket engine. But then I think you are going to say that an observer cannot discriminate between gravity in curved spacetime and a rochet engine in flat spacetime due to the principle of equivalence. But at least for the acceleration he could isolate the effect of a rocket when he knows he has his rocket on or off as this gives the same relation between acceleration mass and force. so you could probably calculate the worldline with and without external forces and calculate only the contribution due to the external force to the difference in time between the watches. at least that should be easy for situations with flat spacetime as there ony the rocket could cause a change in speed.PeterDonis said:Yes.
thanks I will keep in mind.Dale said:If you want something useful, nothing you can study in relativity will be more useful than learning Lagrangian mechanics. And when you do learn the Lagrangian approach it will eventually make studying non-inertial reference frames easier. However, it isn't as "exciting" a topic as relativity.
That is proper acceleration. An accelerometer does detect the acceleration as a result of a rocket engine. It seems like you may have a Newtonian physics misunderstanding here.HansH said:Then it means that I am not referring to the tem ''proper acceleration' but to the accelleration as result of an applied force such as a rocket engine.
I understand all of the words you are using but not the way you are using them.HansH said:Yes. that would probably mean that the main idea of the topic cannot be united with general relativity due to the equivalence principle that cannot isolate an external acceleration from the effect of curvature on the path of a worldline?
I assume I am not talking about the difference between GR and Newtonian physics but the difference between GR with curved spacetime and special relativity with only flat spacetime. probably it helps to draw the worldlines in special relativity with the 2 rockets I used earlier and then calculate the difference between the stopwatches and compare that with the summed up product (integral) of acceleration times the time that the accelaration took at a certain value so integral(a(t)dt) (or probably a more relativistic equivalent that I cannot produce now) and divide that integral by the calculated timedifference between the stopwatches and see if this is a constant or not. But I agree that this should also work in general and for GR because otherwise it is not a valid theory. But proving that a theory is wong only needs one example.Dale said:I understand all of the words you are using but not the way you are using them.
Proper acceleration is the acceleration measured by an accelerometer. Both GR and Newtonian physics can describe the acceleration measured by an accelerometer. The difference between GR and Newtonian physics is not regarding proper acceleration. It is that Newtonian physics considers gravity to be a real force that is just coincidentally undetectable by accelerometers while GR considers gravity to be locally a fictitious force that is undetectable just like all other fictitious forces.
Yes, you are. See below.HansH said:Then it means that I am not referring to the tem ''proper acceleration'
Such an "applied force" causes proper acceleration.HansH said:but to the accelleration as result of an applied force such as a rocket engine.
Not at all. Remember, in relativity "gravity" is not a force. The force you feel when you stand at rest on the surface of the Earth is not "gravity". It's the force of the Earth's surface pushing up on you. Just as, if you stand at rest on the floor of a rocket accelerating at 1 g, the force you feel is the force of the rocket's floor pushing up on you. The principle of equivalence says that you cannot distinguish these two cases by local observations, but that is not the same as saying that you can't distinguish "gravity" from the effects of a rocket engine in flat spacetime.HansH said:I think you are going to say that an observer cannot discriminate between gravity in curved spacetime and a rochet engine in flat spacetime due to the principle of equivalence.
There is no such thing as "the effect of curvature on the path of a worldline" if by "curvature" you mean "spacetime curvature". That is getting things backwards. It's not that you start out with a worldline, and then you put it in one spacetime geometry or another and see what happens to it. You have the spacetime geometry first, and then you look at the behavior of worldlines in it. There is no way to pick out "the same worldline" in two different spacetime geometries and compare the effects of one spacetime geometry vs. another on "the worldline". There is no way to even define a "worldline" at all independently of a spacetime geometry.HansH said:the equivalence principle that cannot isolate an external acceleration from the effect of curvature on the path of a worldline?
If you want to put gravity in your scenario, yes, that would be the usual assumption in this forum since it is the relativity forum.HansH said:I assume I am not talking about the difference between GR and Newtonian physics but the difference between GR with curved spacetime and special relativity with only flat spacetime.
If this means "calculate the difference in arc lengths of the worldlines", then yes, this is the general method that always works, whether spacetime is flat or curved.HansH said:probably it helps to draw the worldlines in special relativity with the 2 rockets I used earlier and then calculate the difference between the stopwatches
I'm not sure what you are trying to accomplish with all of this. But whatever it is, as I have already pointed out several times now, it would only be applicable to this scenario and nothing it might tell you would generalize usefully to other scenarios.HansH said:and compare that with the summed up product (integral) of acceleration times the time that the accelaration took at a certain value so integral(a(t)dt) (or probably a more relativistic equivalent that I cannot produce now) and divide that integral by the calculated timedifference between the stopwatches and see if this is a constant or not.
I am not sure that there is any reasonable way to compare the lengths of two worldlines in different spacetimes. I mean, you can certainly compare their lengths, but trying to say the difference in length was caused by something seems impossible. Two different spacetimes are causally disconnected by definition.HansH said:the difference between GR with curved spacetime and special relativity with only flat spacetime
I talked about acceleration during a certain time interval. so not ony the acceleration but also the duration of the accelleration. so it is about the combination of acceleration during a certain time interval (causing a speed difference between the 2 rockets) and the building up rate of the difference between the clocks. of course the difference in clocks builds up over the time that the speed difference remains, so the interval of keeping th speed difference before going back to same speed for both rockets also is in the relation. So I would expect you could write this down in a total equation something like :Dale said:I can produce scenarios where this is not true. You can have double the acceleration with the same difference between clocks.
The point is that mass curves spacetime and mass also resists against a change in speed. and a change in speed is acceleration and aceleration also plays a role in curvature of spacetime. So as I assume these are both properties of mass, it could well be that there is an underlying common reason for both properties to behave like this that we possibly cannot see because it could be in the machinery behind nature that we cannot see. so if this is the case there should be some relation so that was where I was looking for and if this was probably already known in the physics community.PeterDonis said:I'm not sure what you are trying to accomplish with all of this. But whatever it is, as I have already pointed out several times now, it would only be applicable to this scenario and nothing it might tell you would generalize usefully to other scenarios.
These are two different concepts of "mass". The precise term for the first one is "stress-energy", and the mathematical entity that embodies it in relativity is the stress-energy tensor.HansH said:The point is that mass curves spacetime and mass also resists against a change in speed.
No. Proper acceleration is not a "change in speed", it's path curvature of a worldline.HansH said:a change in speed is acceleration
Your approach here is based on some fundamental misconceptions (see my post #106 just now). As I have already commented multiple times now, you might be able to get something like this to work in certain particular scenarios, but nothing you learn from that will generalize. IMO you would be far better served by dropping this entirely and focusing on the geometric approach.HansH said:I talked about acceleration during a certain time interval. so not ony the acceleration but also the duration of the accelleration. so it is about the combination of acceleration during a certain time interval (causing a speed difference between the 2 rockets) and the building up rate of the difference between the clocks.
No, that's not what you have been given. What you have been given is an honest response telling you that what you say you want is not possible. What you say you want to accomplish in #105 cannot be done. If you don't want to accept that answer, that's up to you, but to characterize it as "a shot in the back" is wrong. We can't help it if the actual physics doesn't allow you to do what you want to do.HansH said:I am given twice a shot in the back.
I think you still do not understand my point. of course I can agree on your conclusion that things are not possible and that there is not such relation as I brought into the discussion. You are the expert here. But when you are saying I react within 5 minutes and keep a stopwatch to see how fast I respond then I feel that as not respectfull and intimidating. and if I dare to ask a question that comes into my mind because I am a creative person in life helping technology forward with 75+ patents on my name helping my company to be the world leader, then you probably also can imagine that I have enaugh esperience to not letting anyone intinidate me. also not if I ask a question that does not fit into the logical sequence how normally a physics study is organized and get that back as my fault.PeterDonis said:No, that's not what you have been given. What you have been given is an honest response telling you that what you say you want is not possible. What you say you want to accomplish in #105 cannot be done. If you don't want to accept that answer, that's up to you, but to characterize it as "a shot in the back" is wrong. We can't help it if the actual physics doesn't allow you to do what you want to do.
If that specifically is what you are concerned about as being "a shot in the back", you should reference it specifically. (You can also use the Report button to report posts that you think violate PF rules.)HansH said:when you are saying I react within 5 minutes and keep a stopwatch to see how fast I respond
Nobody is saying you can't ask questions that come into your mind. But in this thread, you have repeatedly been asking questions that are based on fundamental misconceptions of yours, and the answers you have gotten are trying to tell you that--which amounts to telling you that in order to learn what you say you want to learn, you are first going to have to unlearn things that you think you already know. It's not clear that you've grasped that and considered its implications.HansH said:if I dare to ask a question that comes into my mind
It's not a matter of "fault". It's a matter of what works and what doesn't in learning these things. See my comments above.HansH said:also not if I ask a question that does not fit into the logical sequence how normally a physics study is organized and get that back as my fault.
Ok, good. That's the ultimate goal.HansH said:for me this topic is sufficiently answered to be able to continue for a while with the input I got
Good.HansH said:so probably I will come back later with some more knowledge.
That's not an issue. By all means come back with further questions once you have continued for a while on your own.HansH said:(If I am allowed after mentioning things by name as I just did)
HansH said:thanks I will keep in mind.
Thanks. 1 or 2 years ago I already followed the lecture video's about special relativity and also a part of the lectures about general relatvity. alt a certaim monent I lost the overview over the general relativity part and after some time started from scratch again. Then I saw that whe I viewed it for the second time I could follow more than the first time. so it seems difficult to to get this clear from video's alone. I think however more exersices would be needed as following a video only doesn't give the problems one runs into when doing yourself. so that is a thing I need to solve in some way also.Sagittarius A-Star said:Here you can find good lecture videos from Leonard Susskind as introduction:
https://theoreticalminimum.com/courses
You can find there a lecture video about the Lagrangian for classical mechanics under
You can find lecture videos about Special Relativity (including relativistic laws of motion) under
- "Classical Mechanics": Lecture 3
- "Special Relativity and Electrodynamics": Lectures 1 to 3
Related textbooks:
The problem with such online-movies is that you tend to just watch the movies and think you have understood the material. This is particularly true for well-presented movies like the Susskind movies. The important point is that you have to sit down and do something actively with the material to see, whether you can work with the material, particularly solve problems for yourself. This holds, of course, true also for textbooks, manuscripts, and papers.HansH said:Thanks. 1 or 2 years ago I already followed the lecture video's about special relativity and also a part of the lectures about general relatvity. alt a certaim monent I lost the overview over the general relativity part and after some time started from scratch again. Then I saw that whe I viewed it for the second time I could follow more than the first time. so it seems difficult to to get this clear from video's alone. I think however more exersices would be needed as following a video only doesn't give the problems one runs into when doing yourself. so that is a thing I need to solve in some way also.
2 questions at this stage:Dale said:be comfortable using the Lagrangian for classical physics.
