Calculating Force Exerted by Laser Beam on a Mirror
The discussion focuses on calculating the force exerted by a laser beam on a mirror, specifically a 1 W laser beam reflected perpendicularly. The key equations utilized include the relationship between power, energy, and momentum of photons, leading to the conclusion that the force is approximately 6.67 x 10-9 N. The factor of 2 in the force calculation arises from the change in momentum when photons reflect off the mirror, as opposed to being absorbed.
  • Understanding of photon energy and momentum, specifically E = hν and P = h/λ.
  • Familiarity with the principle of conservation of momentum.
  • Knowledge of basic optics, particularly the behavior of light upon reflection.
  • Basic grasp of laser physics and power calculations.
  • Study the derivation of the momentum of photons in detail.
  • Explore the implications of light pressure in optical trapping techniques.
  • Learn about the applications of laser beams in engineering and physics.
  • Investigate the differences in force calculations for absorbed versus reflected light.
Students in physics, optical engineers, and anyone interested in the interaction between light and matter, particularly in applications involving lasers and reflective surfaces.
Matthaeus_
A laser beam (\mathrm{Power} = 1\ \mathrm{W}) is completely reflected by a mirror perpendicular to the beam. Light is made of photons, and each photon carries an energy E = h\nu and a momentum P = h/\lambda, where \nu is the frequency, \lambda is the wavelength and h is Planck's constant. Find the force with which light pushes the mirror.
Apart from those already present in the problem statement, I have:
\lambda \nu = c
F = \frac{dp}{dt}
Each second, the light source emits n photons, each one carries an energy E = h\nu = hc/\lambda, for a total power of 1\ \mathrm{W}. This gives:
\displaystyle n = \frac P E = \frac{\lambda}{hc}
In one second then, n photons hit the mirror and bounce back, which gives:
\displaystyle F = \frac{dp}{dt} = n \cdot 2p = 2 \frac{\lambda}{hc}\cdot \frac{h}{\lambda} = \frac 2 c \approx 6.67\cdot 10^{-9}\ \mathrm{N}
The result is somewhat intuitively pleasing, can you check it is correct, please?
Looks good to me.
Whew... Thank you Doc for checking :)
Sorry to dig up such an old question, but after looking at this question, I don't understand were the 2 comes from in the F=n2p. Could someone explain this to me?
Thanks
The momentum is twice the incoming photon's because it bounces back
Think of a ball, if you throw it to hit a wall and stop then you need twice as much force for it to hit the wall and come back at the same speed.
That is to say, if it was not a mirror, and the light did not reflect off the surface, the 2 would be a 1 instead?
It comes from the fact that the change in momentum is twice the original momentum.
Yes. If the light is absorbed then it's a 1. As Doc Al said, it's all about change in momentum.
