Force from water pressure on a submerged wall
  • Thread starter Thread starter pianoman2700
    Fluids Forces
7 replies · 3K views
pianoman2700
[SOLVED] Fluids and Forces
Hi, I'm new to this site, so I'm not sure if this is the right place to post. I found a year-old entry with the same question that I'm having trouble with, found here:
https://www.physicsforums.com/showthread.php?t=153538"
For Part a, I followed the same method that PremedBeauty followed, but can't seen to get the correct answer. Is there a force that I am missing?
For Part b, I integrated to try and find the total force, but, once again, my answer comes out incorrect. My calculations for part b are below.
F=force
(atm)= atmospheric pressure (in Pascals)
p= density of water
g=gravity
h= depth of water
dh= change in depth of water
A= area = width*h
D = depth (as defined by problem)
F=((atm) + pgh)*A
But because pressure changes with depth, we must integrate
dF = ((atm) + pgh) * (width*dh)
Integrating yields:
F= (atm)(width)(h) + (.5)(p)(g)(h^2) evaluated from 2D to 3D
Evaulating yields:
F= 3D^2((atm) + 1/5pgD) - 2D^2((atm) + pgD)
The answer that I get from this calculation does not agree with the correct answer; is there something I am missing?
Not sure what you are missing since you didn't show the calculation for part a.
For part a you should have:
[tex]F_A = P_A \cdot A_A[/tex]
where,
[tex]F_A[/tex] is the force in Newtons
[tex]P_A[/tex] is the pressure on face A in Pascals
[tex]A_A[/tex] is the area of face A in square meters
If your problem is the same as the picture in the other link then you have,
[tex]P_A = P_{fluid} + P_{atm}[/tex]
and
[tex]A_A = d^2[/tex]
Hence the force acting on face A is,
[tex]F_A = (P_{fluid} + P_{atm}) \cdot d^2[/tex]
Now with [tex]P_{fluid} = \rho gh[/tex] and [tex]h = 2d[/tex] you get,
[tex]P_{fluid} = \rho g \cdot 2d[/tex]
Which yields,
[tex]F_A = (\rho g \cdot 2d + P_{atm}) \cdot d^2[/tex]
Just plug in the value for [tex]P_{atm}[/tex] in pascals, along with the other missing, but given, values and you'll have the force.
CS
CS
Alright, thank you. I meant to refer calculations for part 1 to those that the previous poster did (as I went through those same steps). I came up with the same answer that was displayed here, but it disagrees with the answer given. An error on the part of the book, I think...
Make sure your units are correct.
BTW, What did the book give for the answer?
I'm not sure; it's an online homework assignment. It tells me if I'm right or wrong, but won't tell me the actual answer until I've gotten it correct.
Are you able to help on the second part? (Part b)
You'll have to integrate to find the force.
[tex]F = P_{atm} \cdot A_B + \rho g \int_{a}^{b} h \cdot dA[/tex]
where,
[tex]A_B[/tex] is the area of face B
[tex]h[/tex] is the height
[tex]dA[/tex] is the area of some small strip across the face
The limits of integration, a and b, would be the starting and ending height (depth), i.e. 2d to 3d respectively.
Hope that helps.
CS
stewartcs said:
Hope that helps.
CS
Apparently it only wanted the gauge pressure, so I subtracted out the air pressure, and everything worked out great. Thanks for your help.
No problem. I was going to suggest trying that if you were still having problems.
CS
