Force question on pulling worker
  • Thread starter Thread starter StephenDoty
    Force
7 replies · 3K views
StephenDoty
A worker pulls horizontally on a rope that is attached to a 10-kg crate resting on a rough
floor. The coefficients of static and kinetic friction are 0.5 and 0.3, respectively. The
worker pulls with a force of 40 N. The frictional force exerted by the surface is...??
the box is moving because fk<fs
If the Fnet is not 50N, the applied force then
Fnet= T - fk
Fnet= 50N - fk
and of cource fk= .3 * 10 * 9.8 = 29.4N
Is this right??
Yes it does move because fk= umg and fs=umg and since us>uk fk<fs which means that the object moves and accelerates, right??
I don't understand your reasoning. Instead, figure out the maximum force that static friction can deliver given the nature of the surfaces. Compare that maximum value with the applied force.
ok...the fs=49N which is < the 40N push. So the box is not moving. So is the fk= 40N so fnet= 0 = fp - fk?
Good. The maximum possible static friction force is 49 N, which is more than enough to handle the applied force of 40 N. So the box doesn't move.
Since it doesn't move, fk (kinetic friction) is irrelevant.
But the net force is zero, so what must be the friction?
40N
thank you very much
