Force Questions: Calculate Friction & Find Net Force
  • Thread starter Thread starter zelda1850
    Force
9 replies · 10K views
zelda1850
A force of 10 Newtons toward the right is exerted on a wooden crate initially moving to the right on a horizontal wooden floor. the crate weights 25 Newtons.
A) calculate the magnitude of the force of friction between the crate and the floor
B) name the vertical forces acting on the crate
C) name the horizontal forces acting on the crate
D) what is the magnitude of the net force acting on the crate
E) is the crate accelerating?
A) u*Fn = ff (how can i find out u?)
b) weight is 25 Newtons so fg and fnormal is 25 Newtons
c) applied force is 10 Newtons
d) m*a = f net or applied force - ff = fn (mass and acceleration isn't given so i can't use it)
im stuck with the equations can someone help =)
Moving crate on the wooden floor will come to rest due to frictional force. If you want to keep it moving, you have to apply a force to overcome the frictional force. If the crate moves with uniform velocity, then the frictional force is equal to the applied force.
emm there is an apply force on the crate but how i know if it moves in uniform velocity?
can someone help me figure out the force of friction?
As rl.bhat noted, the friction force must equal the applied force if the crate is moving with constant velocity. The problem statement, however, is incomplete. Is there missing information? Without knowing that it moves with constant velocity, it cannot be solved without additional data.
hmm so can this problem be solved?
so if it moves at constant velocity what can i do to solve the frictional force is there a equation?
