Force with friction problem(determine a force by the angle)
The discussion revolves around determining the force required to move a block on a horizontal surface when pulled at an angle θ, considering static friction. As the angle increases, the normal force decreases, which reduces friction and increases the net force needed to move the block. Calculations for specific angles (0°, 10°, 20°, 30°, 40°, 50°, and 60°) were attempted, but initial results were incorrect due to a sign error in the equation. The user ultimately resolved the issue and expressed a desire to delete the thread, which is not possible. The conversation highlights the importance of careful calculation in physics problems involving forces and angles.
suyashr99
A block of mass m rests on a horizontal table. The block is pulled by a massless rope with a force F at an angle θ. The coefficient of static friction is 0.60. The minimum value of the force needed to move the block depends on the angle θ
a)Discuss qualitatively how you would expect the magnitude of this force to depend on θ.
b) Compute the force for the angles θ = 0°, 10°, 20°, 30°, 40°, 50°, and 60°, and make a plot of F versus θ for mg = 421.3 N. From your plot, at what angle is it most efficient to apply the force to move the block?​
F= ma
F(fric)= μ(N)
For a) If the angle were to be increased, the normal force would be less. Therefore, the force of friction would less too, making the net force larger. If the net force is larger that means F would also be larger. This would be the opposite if the angle was decreased
For b) N = mg - Fsinθ
F(Fric) = Fcosθ
μ(mg- Fsinθ) = Fcosθ
Fcosθ - μFsinθ = μ*mg
F(cosθ -μsinθ) = μ*mg
F = μ*mg / cosθ - μsinθ
Using this, I only got force F at 0 degrees right. The rest were all wrong. Would I need calculus to solve this problem (haven't learned it yet.) Please guide me in the right direction for this problem.
[Edit: I made a simple sign mistake. I should have added μsinθ in the denominator.]
F= ma
F(fric)= μ(N)
F(Fric) = Fcosθ
We can't tell what you did wrong if you don't show your calculations.
Sorry, I ended up figuring out the answer. How do I delete this thread?
You don't. It stays.
Oh okay. I accidentally subtracted μsinθ instead of adding by it. Sorry for all the trouble.
