Upward Normal Force Exerted by Floor on Elevator Passenger
The discussion revolves around the upward normal force exerted by the floor on an elevator passenger, specifically comparing this force to the passenger's weight and exploring the implications of acceleration in an elevator context.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants discuss the setup of the problem using Newton's laws, questioning the correct approach to calculating net force and acceleration. There is a focus on the relationship between normal force and weight, and how to interpret the signs in force calculations.
Participants are actively exploring different interpretations of the problem, particularly regarding the direction of forces and the resulting acceleration. Some guidance has been offered regarding the application of Newton's laws, but no consensus has been reached on the correct approach.
There is an ongoing discussion about the assumptions related to the direction of acceleration and the relationship between normal force and weight, as well as the implications of different scenarios presented in the problem.
Heat
The upward normal force exerted by the floor is 620N on an elevator passenger who weighs 650N.
F=ma
I am reviewing all the Homework assigned so, I do got the answers. :)
Anyways, the way I set this problem up was F=ma.
First we need to know the mass, which we get by w=mg.
650 = m9.8
m = 66.33
now we plug into F=ma.
Fnet = 66.33a
I managed to get the acceleration of .455 , but my question here is , why is the net force 620-650 and not 650-620.
Do we always subtract from the smaller force first? My first instinct was since gravity was larger it would be 650-620.
What if it was this instead: "The upward normal force exerted by the floor is 700N on an elevator passenger who weighs 100N."?
Would it be normal force-w or will it still be w-n. ?
I just need a clarification. o:)
what exactly does the problem ask you to find? The normal force is less because the elevaotr is accelerating in what direction to make the passenger weight less?
It tells me to find acceleration.
I did of -.455
I know because of it being negative it goes down.
but
what if I subtracted 650-620 = 30
then it would be 30/66.33 = .455
a would be positive.
"My first instinct was since gravity was larger it would be 650-620"
the normal force acts against the downward direction.
so u can think of it as 620N + (-650N) .
"Do we always subtract from the smaller force first? My first instinct was since gravity was larger it would be 650-620. "
no, Newtons law is addition of forces so u need to keep your +/- sings with respect to the directions.
Your first problem is that w=mg not ma.
Gravity is commonly measured in units of m s-2, (metres per second squared). hmmm
  • · Replies 21 ·
