What Speed Would the Arrow Leave the Bow if Force Were Doubled?
The problem involves determining the speed of an arrow leaving a bow when the force exerted on it is doubled. The context is rooted in mechanics, specifically relating to forces, acceleration, and kinematics.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between force, acceleration, and speed, noting that doubling the force results in doubled acceleration. They explore the implications of maintaining certain variables constant while questioning what "all else remaining the same" entails.
The discussion is active, with participants engaging in reasoning about the relationships between acceleration, distance, and speed. Some guidance has been offered regarding the use of ratios and the significance of comparing final speeds without needing specific numerical values.
Participants note that the distance the arrow travels to reach its final speed is assumed to remain constant, although the actual distance is not specified. There is also a focus on the unknown acceleration and how it relates to the problem.
Amber430
This problem really shouldn't be this difficult but for some reason I can't seem to find the answer.
An arrow, starting from rest, leaves the bow with a speed of 26.0 m/s. If the average force exerted on the arrow by the bow were doubled, all else remaining the same, with what speed would the arrow leave the bow?
net force= mass x acceleration
Acceleration is unknown in this question. Velocity (I'm assuming it's the final V?) is known (26.0 m/s). Initial velocity is 0. I know that when force doubles, acceleration doubles. That's about as far as I could get.
Good. What quantity remains the same? When they said "all else remaining the same", what could they have been talking about?
The initial velocity remains the same. But the only other variable that is given is final velocity, which would not stay the same.
Hint: The distance the arrow takes to reach the final speed is the same.
How do distance, acceleration, and speed relate?
V^2=Vo^2 + 2ax. But what is x? It isn't known.
All you want to do is compare the final speeds. You don't need to know the actual distance. Just call it x.
But what is the acceleration?
Again, you don't need actual numbers. Call the original acceleration "a". What would be the new acceleration?
It would be 2a
Amber430 said:
It would be 2a
Good. Now solve for the speeds in terms of "a" and "x" and compare. (You can also use ratios.)
14K
