Forces on Equilateral triangle truss
The discussion centers on analyzing forces in an equilateral triangle truss with each side length denoted as 'l'. A horizontal force 'F' is applied at the apex of the triangle. Participants calculated moments at the supports, concluding that the moments are (½)F. The force in member AD was determined to be equal to F, while member AB was found to have zero force, prompting questions about the accuracy of these findings.
  • Understanding of static equilibrium principles
  • Familiarity with truss analysis techniques
  • Knowledge of force decomposition in two dimensions
  • Basic concepts of moment calculations
  • Study methods for analyzing truss structures using the method of joints
  • Learn about calculating forces in trusses using the method of sections
  • Explore the implications of zero-force members in truss design
  • Review examples of moment calculations in static structures
Engineering students, structural engineers, and professionals involved in truss design and analysis will benefit from this discussion.
tom676
Hey Guys,
My question involves finding all of the forces acting upon each member. It is known that each side of the triangle has a length of l. It is also known that the force is acting at the very top of the triangle in the x direction (to the right) labelled as F.
Attempt:
I found moments at both supports (bottom left + bottom right) to be (½)F. I have found that AD = F and for some reason AB = 0?
Is this incorrect?
How about showing the work you have done so we can see how you are thinking? That would help a lot.
  • · Replies 21 ·
