How Much Air Is Needed to Cool Water in a Copper Tube?
The discussion focuses on determining the amount of air required to cool water flowing through a copper tube from 70°C to 35°C within a two-minute timeframe. The user has established that approximately 250 W of cooling power is necessary. Key factors include the water's flow velocity, the tube's dimensions (3/8" diameter), and the ambient air temperature (22-27°C). The user seeks equations to calculate the required air velocity for effective cooling.
  • Understanding of heat transfer principles
  • Familiarity with thermodynamics concepts
  • Knowledge of airflow calculations
  • Basic understanding of specific heat capacity of air
  • Research the equation for convective heat transfer to determine air velocity
  • Learn about specific heat calculations for air at varying temperatures
  • Investigate fan specifications suitable for cooling applications
  • Explore flow rate calculations for water in a copper tube
Engineers, HVAC professionals, and anyone involved in thermal management or cooling system design will benefit from this discussion.
Vig16
I was asked to determine how much Air is needed to cool a copper tube. The air will be blowing on the outside surface of the tube as there will be water running through the tube.
The starting temperature of the water will be 70°C and the goal end temperature is 35°C...all done in less than 2 minutes. I already know that it will take ~250 W to do this; however, how would I determine the amount of air needed? Am I looking for the velocity of the air to cool it? If so, what equation should I use to solve for this?
I won't be able to have room temperature water available to cool the solution, neither will I be able to use ice. This needs to be repeated on command, so I'll need a fan that will kick on to cool the piping as the 70°C starts flowing through.
As you can see I'm quite rusty on my heat transfer and thermodynamics. It doesn't help that I can't find my textbook from when I was in school either!
A few questions:
  • Is the water flowing through the pipe or is it being stagnantly held in place? If it's flowing, at what velocity?
  • What's the length and diameter of the pipe?
  • What temperature is the ambient air at?
If you know the required power you can simply multiply the desired airflow by the specific heat of air and desired delta-T... then add a safety factor.
Sorry about that. I'll answer your questions in order...
1. The water is flowing through the pipe, but the velocity is not determined yet. I can make it as fast or slow as I want so long as I can dispense 8oz of water in 2 minutes which is what I need to cool (sorry for leaving that important fact out).
2. The pipe is 3/8" diameter and right now it's in an aluminum box that's 5"x6"x1.5". I can have copper tubing leading into it as well though.
3. The ambient air is at 22-27 deg C
ddelaiarro said:
A few questions:
  • · Replies 16 ·
