Fortran 77 character variable initialization with g77
  • Context: Fortran
  • Thread starter Thread starter nds
    Assignment Fortran77
5 replies · 4K views
nds
fortran77 statement -- character assignment
Hi, I am porting an application written in fortran 77 to linux. The following code compiles well with IBM xlf compiler on AIX. However, when I use g77, it fails with the following error:foo.f:6:
+ var /ZFF/
Invalid declaration of or reference to symbol `zff' at (^) [initially seen at (^)]
I am not sure how ZFF is internally interpreted. I also tried using DATA var /ZFF/ (not that there are no singl quotes around ZFF.) but it doesn't work with g77
Can someone please help? Thank you.
Code:
program  test
      CHARACTER * 1
     +             var /ZFF/
	   write(*,*) "printing var=", var
	   return
end
Your program is trying to initialize a one-byte character variable "var" using hexidecimal format. The 'Z' in the data assigment (/ZFF/) is the format deliminator for hexidecimal that let's the program know that the following should be interpretated as HEX.
I can't remmeber if g77 supports this or not. If not, your going to have to resort to some work-arounds.
nds said:
Code:
      CHARACTER * 1
     +             var /ZFF/
These two lines look like they're intended to be a single statement, split (for some unknown reason) into two lines. In traditional fixed-format FORTRAN, the '+' in position 6 indicates that the second line is a "continuation" of the preceding line.
In fixed-format, the compiler discards the '+' after interpreting it as a continuation character. I suspect that you're compiling the program in free-format, in which the '+' would not be treated as a continuation character but instead as an arithmetic '+'.
Try collapsing the two lines together:
Code:
      CHARACTER * 1 var /ZFF/
I'm pretty sure using Z to mean hexadecimal data is non-standard fortran. I used to use IBM hardware quite a lot, but and I don't remember that feature.
Another possibility is that ZFF is a pre-processor constant that is defined somewhere else (maybe in the makefile, not in the source code). In that case, its value could be anything.
My next move would be to read the code and see what "var" is used for. It seems a fairly "anonymous" sort of variable name...
FWIW you can assign var to hexadecimal FF in standard fortran with
CHARACTER*1 var
var = char(255)
AlephZero , TheoMcCloskey -- thank you very much! Now I understand that Z is the format delimiter and I think var = char(255) is exactly what I need. Thank you again!
i need a fortran tutorial for begginers, kindly help
