Fortran Program - Calculate the Function
Haleemos
F(x) = exp(-a x^2) cos bx
for -100 =< x >= 100 , a=13 and b=7.
program main
implicit double precision (A-H,O-Z)
implicit integer (I-N)
DO I = -100,100
X = I * 1D0
F = DEXP(-A * X**2) * DCOS(B * X)
A = 13
B = 7
PRINT*,F
ENDDO
STOP
END
Have you tested the program to see if it works?
Because it will not give the right result. Check the order in which you are doing things.
Haleemos said:
but the answers all zero
Are you sure about that? Because it is not the case when I run it.
You only made one mistake, which is that a and b are set too late. And they shouldn't be inside the loop: set them at the beginning of the program. Might as well also set them directly as double precision
Code:
a = 13.d0
b = 7.d0
Also, instead of multiplying by 1D0, set I to double precision using
Code:
X = dble(I)
This is more efficient as there will not be an unnecessary multiplication every time.
I also suggest that you print out both x and F, which makes it easier to check the output and plot the results.
