Fortran program missing end statement for PROGRAM Lab5A
4 replies · 4K views
suezxc6
im trying to compile this program but i get this error
print*, cap= one (m:m)------------------------------Capitalize:
Error: Invalid form of PROGRAM statement at (1)
Fortran:
program Lab5A
      implicit none
      ! This program introduces Fortran string handling capabilities
      character*26 upper, lower, name, cap
      character str*2, one*1
      integer from, to, i, m
      lower = "abcdefghijklmnopqrstuvwxyz"
      upper = "ABCDEFGHIJKLMNOPQRSTUVWXYZ"
      name = "loool"
      ! ---------------------------------------------------Substrings:
      do i = 1, 5
         print*, "The string we are studying is: ", name
         print*, "Enter two integers ..."
         read*, from, to
         print*, name(from:to)
      end do
      ! ---------------------------------------------------Pattern:
      do i = 1, 5
         print*, "Enter any 2-character string (e.g. enter er) ..."
         read 5, str
         print*, index(name,str)
      end do
    5 format(A)
      ! ---------------------------------------------------Capitalize:
      do i = 1, len(name)
         one = name(i:i)
         m = index(lower,one)
         if (m .ne. 0) then
            one = upper (m:m)
         end if
         cap(i:i) = one
       end do
       print*, cap
       end
suezxc6 said:
Homework Statement:: I am trying to compile this program but i get this error
Relevant Equations:: ,
Fortran:
program Lab5A
      implicit none
      name = "loool"
      do i = 1, 5
         read*, from, to
      end do
      do i = 1, 5
         read 5, str
      end do
    5 format(A)
      do i = 1, len(name)
         one = name(i:i)
         if (m .ne. 0) then
            one = upper (m:m)
         end if
         cap(i:i) = one
       end do
       print*, cap
       end
The error you show doesn't agree with the code you listed. The compiler is complaining about this line print*, cap= one (m:m)------------------------------Capitalize:
but there's no line that looks like that in your code. My suggestion is to save your code, and then recompile, and see if you get the same error again.
i did just as you requested and still got this
Here's what I would try -- remove all spaces from the label 5 in your format statement.
Fortran:
    do i = 1, 5
        read 5, str
    end do
5 format(A)
Older Fortran versions were very picky about what could appear in a given column. Perhaps your compiler is complaining that the label for your format statement isn't in the right place.
You could also get rid of the format statement completely.
Fortran:
read *, str
Are you sure that you can put an entire array name in the print statement of line 38? It might just want a single ellement. In older FORTRANs one had to loop some way through the elements. The loop can be included in the print statement like:
WRITE(*,*) (x(i), y(i), i=1, n)
