FORTRAN: second-order ODE with Euler Method
The forum discussion focuses on solving a second-order ordinary differential equation (ODE) using the Euler method in Fortran. The equation models the motion of a particle falling under gravity with air resistance. The initial conditions are set with a mass of 1 kg and gravitational acceleration of 9.8 m/s². The user provided an incomplete Fortran program that requires corrections in the DO loops for proper execution, specifically by defining the upper limit for the loop control variable.
  • Understanding of second-order ordinary differential equations (ODEs)
  • Familiarity with the Euler method for numerical solutions
  • Basic knowledge of Fortran programming language
  • Concept of initial value problems in differential equations
  • Review Fortran syntax for DO loops and control structures
  • Learn about numerical methods for solving ODEs, focusing on the Euler method
  • Explore plotting techniques in Fortran to visualize results
  • Investigate the effects of air resistance on falling objects in physics
Students and educators in physics and engineering, Fortran programmers, and anyone interested in numerical methods for solving differential equations.
Cecily
Dear all, please help. I have tried this question and came up with strange numbers, my fortran is definitely not correct. Please help!
When the effect of the air resistance is taken into account, the equation of motion for a particle of mass
m falling vertically in a gravitational field is given by
m*y''= -m*g - b*v (*)
where g is the gravitational acceleration and v = dy/dt is the velocity. The coefficient b specifies the strength of the interaction between the air and the particle. The initial conditions are y(0) = 1000 m and v(0) = 0 ms-2. Take m = 1 kg and g = 9.8 ms-2 in the following.Write a Fortran program that uses the Euler method to solve the initial value problem.
Consider the case without air resistance b = 0. Plot y(t) against t until y = 0 (i.e., the particle has
reached the ground) for two different time steps Δt = 1 s and 0.01 s in one figure. Plot also the
exact solution in the same figure for comparison.
here is my definitely wrong program...
PROGRAM lab5a
IMPLICIT NONE
INTEGER :: i
REAL :: dt, y_0, v_0, f
REAL, DIMENSION(200) :: y, v, t
REAL, PARAMETER :: epsilon = 1D-6
y(1) = y_0
v(1) = v_0
dt = 1.D0
DO i=2
y(i) = y(1) + v(i-1)*dt
v(i) = v(i-1) + dt*f(y(i-1), v(i-1))
t(i) = t(i-1) + dt
WRITE (10, *) t(i), y(i)
IF (y(i) < epsilon) exit
END DO
dt = 1D-2
DO i=1
t(i) = t(i-1) + dt
WRITE (11, *) t(i), y(i)
END DO
END PROGRAM lab5a
REAL FUNCTION f(y, v)
IMPLICIT NONE
REAL :: y, v
REAL :: m=1, g=9.8, b=0
f = -g - b / m * v
END FUNCTION
PROGRAM lab5a
IMPLICIT NONE
INTEGER :: i
y(1) = y_0
v(1) = v_0
dt = 1.D0
DO i=2
t(i) = t(i-1) + dt
END DO
dt = 1D-2
DO i=1
t(i) = t(i-1) + dt
END DO
END PROGRAM lab5a
IMPLICIT NONE
REAL :: y, v
f = -g - b / m * v
END FUNCTION
Your DO loops are not right. For the first one, you have
DO i=1
END DO
You need to indicate the final value of your loop control variable, like this:
DO i=1 , 10[/color]
END DO
Your other DO loop has the same problem.
  • · Replies 22 ·
