Fortran Why am I getting a Segmentation fault: 11 when running my Fortran code?
  • Thread starter Thread starter RissaR
    Fault Fortran
The discussion centers on a "Segmentation fault: 11" error occurring in a Fortran program, specifically at the line checking if `h_temp` equals `blayer`. The user reports that a preceding print statement works without issue, leading to confusion about the source of the error. Suggestions include commenting out the print statement to isolate the problem, as well as implementing debugging techniques such as adding stop statements to trace execution flow. There's a caution against using the equality operator `==` for comparing real numbers due to potential precision issues, recommending the use of a tolerance instead. Ultimately, the user identifies that the segmentation fault was caused by not allocating space for the head and tail vectors after the relevant conditional block, resolving the issue.
RissaR
I'm getting a "Segmentation fault: 11" when running at line 72:
Code:
  IF (h_temp == blayer) THEN
However, the line above it:
Code:
  PRINT *,h_temp==blayer
runs just fine. Needless to say, I'm clueless. Here's my entire code.
Code:
PROGRAM bunkers
      IMPLICIT NONE
      REAL, DIMENSION(5) :: ulist,vlist,hlist
      REAL, DIMENSION(2) :: wind
      INTEGER :: numvars
      ulist = (/ 1,2,3,4,5 /)
      vlist = (/ 4,5,6,6,7 /)
      hlist = (/ 100,200,300,400,500 /)
      numvars = SIZE(ulist)
      CALL meanwind(ulist,vlist,hlist,numvars,150.0,450.0,wind)
      PRINT *,'The mean wind is', wind
      STOP
END PROGRAM bunkers
SUBROUTINE lininterp(ulist,vlist,hlist,numvars,targetlvl,u,v)
      IMPLICIT NONE
      !Dummy argument declarations
      INTEGER, INTENT(IN) :: numvars
      REAL, DIMENSION(numvars), INTENT(IN) :: ulist,vlist,hlist
      REAL, INTENT(IN) :: targetlvl
      REAL, INTENT(OUT) :: u,v
      !Local variable declaration
      REAL :: spacing, currenth, nexth
      INTEGER :: i
      spacing = hlist(2) - hlist(1)
      DO i=1,SIZE(hlist)
            currenth = hlist(i)
            nexth = hlist(i+1)
            IF (targetlvl>currenth .AND. targetlvl<nexth) THEN
                  u=(ulist(i+1)-ulist(i))/spacing*(targetlvl-hlist(i))+ulist(i)
                  v=(vlist(i+1)-vlist(i))/spacing*(targetlvl-hlist(i))+vlist(i)
            END IF
      END DO
      RETURN
END SUBROUTINE lininterp
SUBROUTINE meanwind(ulist,vlist,hlist,numvars,blayer,tlayer,wind)
      IMPLICIT NONE
      REAL, INTENT(IN) :: blayer,tlayer
      REAL, DIMENSION(2), INTENT(OUT) :: wind
      REAL :: umodmean, vmodmean, u, v,angle, headnewx_1, headnewx_2, h_temp,u_temp,v_temp
      INTEGER :: i,j,vmod
      REAL, ALLOCATABLE, DIMENSION(:) :: tailvect,headvect
      REAL, DIMENSION(2,1) :: a, headnewx, meanwindmat
      REAL, DIMENSION(2) ::   vector,modheadvect,vect,modmean
      REAL, DIMENSION (2,2) :: rotation,counter
      !Find head and tail wind vectors
      DO i=1,numvars
            h_temp = hlist(i)
            u_temp = ulist(i)
            v_temp = vlist(i)
                  ALLOCATE(tailvect(2))
                  tailvect = (/ u_temp,v_temp /)
            ELSE IF (h_temp == tlayer) THEN
                  ALLOCATE(headvect(2))
                  headvect = (/ u_temp, v_temp /)
            ELSE IF (h_temp >= tlayer) THEN
                  EXIT
            ELSE
                  EXIT
            END IF
      END DO
      IF (.not. allocated(tailvect)) THEN
            CALL lininterp(ulist,vlist,hlist,numvars,blayer,u,v)
            tailvect = (/ u,v /)
      END IF
      IF (.not. allocated(headvect)) THEN
            CALL lininterp(ulist,vlist,hlist,numvars,tlayer,u,v)
            headvect = (/ u,v /)
      END IF
      !Move coord sys so tail vect is origin
      modheadvect = (/ headvect(1)-tailvect(1),headvect(2)-tailvect(2) /)
      angle = acos(modheadvect(1) / sqrt(modheadvect(1)**2.0 + modheadvect(2)**2.0))
      IF (modheadvect(2) .lt. 0) THEN
            angle = -1*angle
      END IF
      rotation = RESHAPE((/ cos(angle),sin(angle),-1*sin(angle),cos(angle) /),(/2,2 /))
      counter = RESHAPE( (/cos(angle),-1*sin(angle),sin(angle),cos(angle) /),(/2,2/))
      !Rotate hodograph so x-axis along mean shear vector
      vmod = 0
      j = 0
      DO i = 1,SIZE(hlist)
            IF (hlist(i) .ge. blayer .and. hlist(i) .le. tlayer) THEN
                  vect = (/ ulist(i) - tailvect(1),vlist(i)-tailvect(2) /)
                  a = RESHAPE((/ rotation(1,1)*vect(1)+rotation(2,1)*vect(1),rotation(1,2)*vect(2),rotation(2,2)*vect(2) /),(/2,1/))
                  vmod = vmod + a(2,1)
                  j = j + 1
            ELSE IF (hlist(i) .gt. tlayer) THEN
                  EXIT
            ELSE
                  EXIT
            END IF
      END DO
      !Rotate head vector to make it new x-axis
      headnewx_1 = rotation(1,1)*modheadvect(1)+rotation(2,1)*modheadvect(1)
      headnewx_2 = rotation(1,2)*modheadvect(2)+rotation(2,2)*modheadvect(2)
      headnewx = RESHAPE((/headnewx_1,headnewx_2/),(/2,1/))
      !WIND MEASUREMENTS MUST BE EVENLY HEIGHT-DISTRIBUTED IN THE VERTICAL FOR THESE TO WORK
      !Mean u wind is half of diff b/w bottom and top u
      umodmean = headnewx(1,1) / 2.0
      !Mean v wind is average of v obs in coord sys
      vmodmean = vmod/j
      !Rotate coord system back
      meanwindmat = RESHAPE((/counter(1,1)* umodmean,counter(2,1)*vmodmean/),(/2,1/))
      !Add mean wind to tail vector for true mean wind vector
      wind = (/meanwindmat(1,1)+tailvect(1),meanwindmat(2,1)+tailvect(2)/)
      RETURN
END SUBROUTINE meanwind
Any clue what's happening here?
Technology news on Phys.org
Just a guess, but I think that your PRINT statement is causing problems. To test this, comment out this line
Code:
If that eliminates the seg fault, then you know which is the offending code.
Regarding that line, what is it supposed to do? h_temp == blayer will evaluate to true or false, depending on whether the two quantities are equal or not. Is you intent to print TRUE or FALSE?
I put in the PRINT statement just to test whether the statement inside the IF block was evaluating correctly. It was *not* there when the seg fault first occurred and commenting it out (or removing it all together) does nothing. The PRINT statement was only put into check what the problem could be.
you sure?
get a "stop" statement and start placing at various lines to really figure out if the program is failing where you think is failing...compile and re-run every time. Try having a write statement right before the stop...just to make you got there, etc. You know, some good old fashion debugging...it has never failed me.
Is the print statement working? What does it print ? True or False?
I wouldn't trust '==' when comparing two REAL variables...you really need to use some tolerance, there...maybe you think you are going into the "IF () THEN" clause, but you are not...maybe you are going to one of the ELSE clause and maybe even getting out of the DO-loop altogether and the segmentation fault is happening somewhere else.
Please confirm.
(I actually know the answer, but I won't tell you :-) )
gsal said:
you sure?
Good advice.
Please confirm.
I see it, too.
I had already put STOP in several places over and over and had identified that as a break point in the past. I thought that it was still breaking in the same spot, but wasn't (brain fart perhaps). All is fixed now, forgot to allocate space for the head and tail vectors after that specific IF block.
Learn If you want to write code for Python Machine learning, AI Statistics/data analysis Scientific research Web application servers Some microcontrollers JavaScript/Node JS/TypeScript Web sites Web application servers C# Games (Unity) Consumer applications (Windows) Business applications C++ Games (Unreal Engine) Operating systems, device drivers Microcontrollers/embedded systems Consumer applications (Linux) Some more tips: Do not learn C++ (or any other dialect of C) as a...
12K
  • · Replies 54 ·
