Fortran spacing/coordinate question
  • Context: Fortran
  • Thread starter Thread starter kevin86
    Fortran
7 replies · 4K views
kevin86
Since the graphing idea is not available. Does the fortran write/print command let me choose where a number or * is printed at. Like a row column thing if I want to print say a * on the page.
Code:
Something like that. Can I make sure it ends where I want it to end up without counting how many spaces it takes to display something.
Create a character (text) array the size of a print line. Fill it with spaces and asterisks., then print it. You could create a matrix, then print out one row at a time.
I suppose this is the way to do it. I actually needed to give each asterisk an x and y coordinate value, so I can print them out anywhere I choose. But I try this.
You can use a character variable to hold a format statement. That would save you some memory space over jeff's method.
how do i do that, please help, point me in the right direction
I don't think memory space is an issue on a PC in this case. Also if the plot is an alternating pattern of asterisks and spaces, then the character variable for the format statement would be longer than just character array.
I don't really need *, I am happy to use 0 and 1 etc
Well, memory is always an issue for me, on every machine I've used (No 4 GB of RAM isn't really enough. Nor is 500 GB of disk storage), so i thought I'd suggest it.
A format statement of the form:
'(1A, NX, 1A, NX,...)'
will be shorter than the array if N is on average greater than 4.
Also, if you have many lines, it will be more efficient to have one format string that the program creates, and a single array holding coordinates for each *.
On the other hand, I'm used to dealing with 3-D data arrays that have more than 8 million cells, and needing to store a half dozen arrays with that many cells in double precision. So my concern may be unwarranted. I do think your method would be easier to implement, just less memory efficient.
