Fortran:store loop value in array
Antonija
My program calculates the value of a function. Then it prints them on the screen. This is the part:
Code:
do while(x<=b)
variablesvalues(1)=x
x=x+delta
call recog_variables (func, variables)
answer=evaluate(variablesvalues)
print*, answer
end do
What I need to do now is to save theese answers into array and then work with array.
I don't know how to do it, since I tryed some ways and I get some errors which I don't understand...
Code:
niz1(i)=answer
1 do while(x<=b)
x=x+delta
call destroyfunc()
end do
print*, niz1
This version works but when I compile it I get this, which has nothing to do with the numbers I should get:
Code:
  -1.00291508E-09   4.56444949E-41  -3.73914588E-09   4.56444949E-41  -1.00340003E-09   4.56444949E-41              NaN   0.00000000       0.00000000       0.00000000
My opinion: there should be, in my do while loop, nested do loop which is supposed to write the values in the array niz1(i), but I can't declarate it since I don't know how many values will I get. It depends on the interval which is inputed...P.S. How can i insert the FORTRAN code? I have only option to insert java,php,css...
Code:
do while(x<=b)
x=x+delta
print*, answer
end do
In each iteration of the loop, the code above stores the current value of x into variablesvalue(1), the first cell in your array. The call to evaluate() is passed the array, but it might as well have been called with x as the parameter. I don't get what you're trying to do here.
Code:
niz1(i)=answer
1 do while(x<=b)
x=x+delta
call destroyfunc()
end do
print*, niz1
Code:
Declare the array with at least as many elements as you think you will need. Another alternative is to use dynamic-sized arrays, a feature that was added to Fortran sometime after I stopped writing any Fortran code.
Your code above isn't complete, so it's difficult to see what's going on. In the first line you set niz1(i) to answer. This implies that that line of code is inside a counting loop (do i = 1, n). Why are you setting variablesvalues(1) to x? Why is variablesvalues an array if you're only using the first element of the array?
Seeing your complete program would help.
If I put avaluate(x) I get the error. There are used modules and many subroutines. I got the routine online, someone shared it and gave instructions which parts I should change in order to use it in my code...
And, my code is here. This is the first version which works but doesn't store the values into array.
Code:
program ekstremi
use interpreter
!Variables used by the evaluator to build and to determine the value of the expressions
real(kind=8)::X
character(len = 10),  dimension(6) :: variables
real(kind=8),       dimension(100) :: variablesvalues!String variable that will store the function that the evaluator will build
character (len = 275)  :: func
!String variable that will return the building of the expression result
!If everything was ok then statusflag = 'ok', otherwise statusflag = 'error'
character (len = 5)  :: statusflagreal(kind=8)     :: answer
integer::broj,a,b
real::delta=0.1
real, dimension(100)::niz1
print*, 'Dobrodosli! Program racuna  minimum i maksimum unesene funkcije. &
         Unesite zeljenu funkciju:'
read(*,*) func
print*, 'Unesite pocetnu i krajnju tocku intervala:'
read(*,*)a,b!Settings
!The number of variables can be increased
variables(1) = 'x'
x=aprint*,'Izaberi broj:      1)za zatvoreni interval [a,b] &
                           2)za otvoreni interval <a,b> &
                           3)za poluotvoreni interval <a,b] &
                           4) za poluzatvoreni interval [a,b>'
read(*,*) broj
select case(broj)
case(1); goto 1
case(2); goto 2
case(3); goto 3
case(4); goto 4
end select!this is the part which I need to modify in order to store values in array but at the moment not successful in that...
1 do while(x<=b)
x=x+delta
call destroyfunc()
end do
2 variablesvalues(1)=x+delta
3 variablesvalues(1)=x+delta
4 variablesvalues(1)=x
end program
Fortran:
integer i ! Added by Mark44
real (kind = 8) dimension(100) : answerList ! Added by Mark44 -- make larger if you need to. It should have (b - a + 1) * delta cells.
i = 1 ! Added by Mark44
1 do while(x<=b)
      x=x+delta
      answerList(i) = evaluate(variablesvalues)  ! Changed
      i = i + 1
      call destroyfunc()
  end do
Maybe something like this. One thing you'll have to figure out is how big to make what I'm calling answersList. It needs to have (b - a + 1) * delta elements. Possibly you could use dynamic array allocation, which I'm not very well versed in.
Also, for Fortran code, start off with code=fortran in you code tag.
Thank you very much!
Firstly I declared it as dimension 100, for example but if I have 20 numbers to put there then I will get more 80 numbers which should't be there, I suposse fortran put them there from somewhere in the memory...
But than I allocated it and it works. Just one thing, i think that's (b-a+1)*delta isn't correct, I counted it and thought a bit, and think it's (b-a)/delta+1...
It's like this now:
Code:
real(kind=8),dimension(:),allocatable::answerlist
integer::i=1
read(*,*)a,b
d=(b-a)/delta+1
allocate (answerlist(d))
do while(x<=b)
x=x+delta
answerlist(i)=evaluate(variablesvalues)
i=i+1
call destroyfunc()
end do
print*,answerlist
deallocate(answerlist)
Once again, thank a lot!
You're right about the thing with delta. I didn't put that much thought into it.
As for you array, if you put 20 numbers in, then only read 20 numbers out. Instead of doing this -- print *, answerlist -- use a counting loop, printing out one element of the array per iteration:
Fortran:
do i = 1, d
   print *, answerlist(i)
end do
