Forward biased ideal diode=>no voltage drop?
5 replies · 6K views · last reply
pyroknife
Forward biased "ideal" diode=>no voltage drop?
Does a forward biased ideal diode have no voltage drop?
Yes, although it is difficult to say how zero volts can be called forward bias.
Of course, there is some voltage drop across a forward biased diode, but small. See the diode characteristics below.
Current-voltage characteristic graph of a diode, with Vf on the horizontal axis and If on the vertical axis for forward bias and Vr and Ir for reverse bias. Labels mark the breakdown region, PIV, reverse current ~30µA, ON voltage ~0.65V for Si and ~0.2V for Ge, and a note that the reverse current is typical of type 1N4001.
When we speak abut an ideal diode, we either assume zero forward voltage or constant (0.7 V for Si diodes).
Ideal diode current-voltage characteristic: a horizontal axis labelled VOLTAGE and a vertical axis labelled CURRENT, with current zero for negative voltage (REVERSE BIASED) and a vertical rise starting at V_B on the positive side (FORWARD BIASED).
ehild
The "ideal diode" is a convenient fiction which is used when the actual voltage across the diode doesn't matter enough to be included in a calculation.
This is often the case in high voltage designs where the 0.7 volt drop across the diode is trivial compared with the much higher voltages in the circuit.
A voltage of zero volts can't have a polarity.
An ideal diode would have the vertical forward conducting line on the "Y" axis not to the right of it as these graphs show.
Ideal diode has zero volts with non-zero forward current. "Forward biased" refers to direction of conduction current. An ideal diode conducts perfectly in 1 direction (no forward voltage drop). It blocks perfectly in reverse (no leakage current).
Ideal diode has zero volts with non-zero amps in forward direction, vice-versa in reverse.
Did this help?
Claude
