Foucault's pendulum shows absolute motion?
profgemelli
In the 19th century they believed in the absolute motion and the ether, and they were searching for a scientific proof of the motion of the Earth. When Foucaults experiment was done, people still believing that the Earth was still wasfinally convinced that it moves instead.
But it is well known that in the 20th, thanks to Einstein, this belie in absolute motion has been abandoned: motions are relative, there is no eather and no absolute motion... Yet everybody talks without problems of the motion of the Earth, estabilished by Foucaults pendulum experiment, in terms of the 19th century, even in textbooks.
As for me, I have a problem in conciliating modern belief in relativity and relative motions with Foucaults pendulum experiment. Anyone can help? Thank you in advance.
In a sense, acceleration is still absolute in relativity. Newton's inertial frames exist, unchanged, in special relativity. Inertial frames also exist (but drastically changed from Newton's concept) in general relativity.
With GR, Einstein attempted to make all motion relational (Machian). However that objective wasn't realized. Consequently he came back on his earlier claims, admitting that acceleration (incl. rotation) is in a certain sense "real" or "absolute".
Einstein came back to absolute motion? Really? This is new to me! Where and when did he write it?
Not absolute motion, absolute acceleration. Non-gravitational (there are some subtleties about exactly what that term means here) acceleration can be detected and measured without reference to any external body elsewhere in the universe.
It is somewhat startling that the first derivative of position, namely velocity, is relative but the second derivative, acceleration, is absolute. But that's how it is.
The acceleration that is absolute is not the second derivative of position; that's still relative, because it changes when you change coordinates. Absolute acceleration, or proper acceleration is it's usually called, is what you measure with an accelerometer; mathematically, it's the path curvature of the object's worldline, which is invariant--it's the same regardless of which coordinates you use.
Quite true - that's a better way of stating it.
Rotation is also absolute in the sense described above i.e. it can be detected locally by using (ideal) gyroscopes and/or by the presence (or lack thereof) of Coriolis forces. This kind of rotation can be written down covariantly, in a manner similar in spirit to the covariant expression for proper acceleration. So just because "motion" is relative doesn't mean all kinematical quantities are as well.
WannabeNewton said:
... it can be detected locally ...
That "locally" is key. Not quite absolute, which (to me) connotes some notion of universality. Newton's inertial frames are absolute, global in extent. General relativity still has a concept of inertial frames, but they are local.
Rotation in flat spacetime implies (proper) acceleration, so is a particular case of PeterDonis's comment, is it not? Indeed, this thread started with Foucault's pendulum which specifically detects the rotation of the Earth about its axis.
Yes certainly I agree. I suppose I was referring more to the point harrylin brought up about Einstein trying to initially push in the Machian view of rotation.
In that context yes indeed. I just meant that you can equally well use operational techniques to detect rotation in and of itself.
Proper acceleration? Wait a moment. In general relativity a particle which is in free fall, follows a geodesics, i.e. its "proper" acceleration (derivative of the unit velocity vector, tangent to the path curve, with respect of the proper time parameter) is zero. So you are not talking about that. I can't see what you mean with proper acceleration. Is it something linked with spacetime curvature?
Well for starters, proper acceleration is defined for all test particles, not just for freely falling test particles; yes in the special case of freely falling particles the proper acceleration vanishes. Secondly, the point being made by multiple people above is that proper acceleration is absolute. Motion not being absolute does not imply that all kinematical quantities are also not absolute, with one of the simplest counter-examples being proper acceleration.
Thanks for your help, everybody, but I am still trying to understand what Foucaults pendulum measures, according to Einstein gravitation. At the moment, this is my humble reasonment and (probably wrong) conclusion:
Earth in a sense is a free falling test particle, so it should travel on a geodesic path in curved spacetime and have zero acceleration.
But under another point of view it is certainly not a particle but a continuum system, so... there is relative motions of the Earth's particles: which should lead to the geodesic deviation equation!
Is it geodesic deviation what we are talking about? That is linked to the Riemann curvature of the spacetime, that is absolute. As a matter of fact, I thougth that geodesic deviation equation deals with deformable bodyes, otherwise the relative distances of he particles should be constant, but maybe I am wrong about it: all in all, there are no really uncompressible solids in general relativity. So, is it Coriolis force generated, in general relativistic terms, by some component of the Riemann tensor? Foucaults experiment is a local measure of the curvature of the spacetime?
Hi again gemelli! So there's sort of two levels to what you're talking about. First if we consider an object with negligible extended size compared to the characteristic size of the source (so that the effects of tidal gravity are irrelevant), the Coriolis forces vanish if the frame of the object is Fermi-Walker transported; if the object is freely falling then Fermi-Walker transport of its frame corresponds to parallel transport. If the frame of the object is not Fermi-Walker transported then there will be Coriolis forces. This is not related to the Riemann curvature.
Now imagine we have an extended non-spherical body whose center of mass is in free fall in an inhomogeneous gravitational field and whose characteristic size is small compared to the variations of space-time curvature. The inhomogeneity of the object's shape as well as that of the gravitational field will induce a torque on this object and cause it to rotate. More precisely, if the center of mass has 4-velocity ##u^{\mu}## and we attach a spin 4-vector ##S^{\mu}## to the worldline of the center of mass, then along the worldline the spin ##S^{\mu}## satisfies ##u^{\mu}\nabla_{\mu}S^{\alpha} = \epsilon^{\alpha\beta\mu\nu}u_{\nu}u^{\sigma}u^{\lambda}t_{\beta\rho}R^{\rho}{}{}_{\sigma\mu\lambda}## where ##t_{\mu\nu}## is the reduced quadrupole moment tensor of the object and ##\epsilon^{\alpha\beta\mu\nu}## is the volume element. Notice that if the gravitational field is uniform (so that the Riemann curvature tensor vanishes identically) then the spin gets parallel transported along the geodesic worldline of the center of mass.
Ok, dipole, quadrupole... this means something to me. Thank you. I also remember the papapetrou's scheme for a spinning particle, which also involves the Riemann tensor, and maybe that could be another way of seeing the Earth: a spinning particle, i.e. a particle which is not a point test particle, but has some structure. It still seems to me that geodesic deviation equation could be involved too, if we don't assume a polar expansion. In any case when there is a structure the Riemann tensor is involved in the laws of motion for the particle, so this happens for the Earth too.
But still you have not answered me to this question: is this (Riemann curvature of the spacetime) the general relativistic correspondent of Coriolis force that deviates the pendulum in Foucault's experiment?
Funny, I thought the whole point of the Foucault experiment was that the pendulum did NOT deviate, rather it's the Earth (better, the reference frame of the Earth) that turns. And it takes place just as well in flat space, where the Riemann tensor is zero, so that cannot be involved.
The Foucault deviation is caused by the use of a rotating frame/coordinate system, and the Coriolis force is due to the nonvanishing Christoffel symbols in this frame.
Yes, in flat spacetime, i.e. in special relativity, there are inertial frames, and the Earth is not inertial, so you can say that the Earth rotates in absolute terms, and so fictional forces like Coriolis are legitimate. Fictional forces are apparent, and appear only in non-inertial frames.
As far as I know, things should be diferent in general relativity: there are no inertial frames, all reference frames are equivalent, and gravitational forces are equivalent to fictional forces. So there should be no asimmetry between one reference frame and another. Yet rotation, as showed by Foucaults, is, in a sense, absolute... That is to puzzle me. All in all Earth is gravitating object so no absolute acceleration should there be, in general relativistic terms. So which is Einstein's explanation of Foucault's experiment? My possible explanation at the moment is that it is originated by tidal forces, in some way, i.e. in other words Foucaults experiment is a sort of local measure of the curvature of the spacetime.
GR does, however, have a coordinate-independent and frame-independent notion of a geodesic. Foucault's pendulum is trying to follow a geodesic; the trajectory of a point that is stationary in the rotating coordinate system is not a geodesic. This is true and sufficient to explain the precession regardless of the curvature of space near the earth.
Don't think I don't appreciate your effort to explain me this thing, but I still doubt it is so simple, and I just rely to einstein: since in GR all reference frames are equivalent, the force which acts on the pendulum, as seen by an observed on the surface of the earth, in GR in my opinion should be a kind of gravitational force. That's why I try to interpret it in terms of Riemann tensor.
Moreover, if a point which is stationary with respect to the surface of the Earth, like the point where the pendulum is suspended, does not follow a geodesic, as you say, in my opinion the pendulum also should not, due to being suspended to it.
That's why I said that the pendulum is trying to follow a geodesic. It doesn't actually follow a geodesic because it's being tugged off the geodesic by the cable from which it is suspended.
There are at least [STRIKE]three[/STRIKE] four basic misunderstandings in this sentence.
Gravity is not involved in this at all, and neither is GR.
The idea that "all reference frames are equivalent" is merely the statement that the laws of physics are generally covariant, i.e. can be written in a form which holds equally in all reference frames, and this is true in SR too.
Fictitious forces are not the same as gravitational forces. They occur in Newtonian mechanics and in SR, where no gravity is present.
And the Riemann tensor, which truly indicates the presence of a gravitational field, measures the differential or tidal acceleration between two particles, and does not correspond in any way to fictitious forces.
As I said, the object that represents fictitious forces in relativity is the Christoffel symbol.
You need to get past the naive "everything is relative" stage and learn some of the details. In both SR and GR, everything is NOT relative. Acceleration and rotation are absolute.
Again you say that acceleration and rotation are absolute in General relativity.
What can I say? This means that I have completely misunderstood einstein's gravitation. Let me go back to textbooks and see you later...
Yes acceleration and rotation are absolute; this is true even in Newtonian mechanics. You can unambiguously measure them using e.g. accelerometers and gyroscopes. I'm afraid you have indeed misunderstood that aspect.
As I stated, and as Bill repeated multiple times again, the Coriolis forces in a frame arise from the failure of the frame to be Fermi-Walker transported (Fermi-Walker transport defines local non-rotation of frames). This has nothing to do with the Riemann curvature tensor whatsoever. Just like zero acceleration is defined as ##\nabla_u u = 0## (parallel transport of the 4-velocity), Fermi-Walker transport of a frame ##\{e_{\alpha}\}## is defined as ##\nabla_{u}e_{\alpha} - g(e_{\alpha},a)u + g(e_{\alpha},u)a = 0## where ##a = \nabla_u u##. If the frame satisfies this then it is non-rotating and no Coriolis forces will arise in it. This is a statement of an absolute nature just like ##\nabla_u u = 0## is a statement of an absolute nature.
As I stated, and as Bill repeated multiple times again, the Coriolis forces in a frame arise from the failure of the frame to be Fermi-Walker transported (Fermi-Walker transport defines local non-rotation of frames). This has nothing to do with the Riemann curvature tensor as also stated.
Obviously I have no problem to understand that rotation of the Earth is absolute in the framework of Newtonian mechanics, and also in SR. All in all the motion is itself absolute in those frameworks, isn't it? It is the fact that acceleration should be absolute also in GR that conflicts with the way I had understood things.
However there are some items in Misner Thorne Wheeler Gravitation textbook, which I have on my knees now, classified under the subject "Coriolis force", and I am now checking that, maybe I will find some detailed explanation. Later I will tell you if I will get to clarify my ideas, if you want.
Thank you all for kindly trying to help me.
Why does it conflict with your understanding? If you can elucidate on what part of the absolute nature of said quantities is conflicting to you then hopefully we can ameliorate the issues.
As for MTW, check out section 13.6 and exercise 13.14.
profgemelli, I cannot overstate the importance of what Bill_K told you:
This distinction is very important.
The Christoffel symbols (fictitious forces including the Newtonian idea of a gravitational force) are frame variant, or relative. The acceleration due to the Christoffel symbols cannot be detected by an accelerometer and is called coordinate acceleration. It is a mathematical artifact of the coordinate system, not something physical.
The acceleration which can be measured by an accelerometer is called proper acceleration. It is frame invariant, or not relative. All reference frames and coordinate systems agree on its value. Focault's pendulum is undergoing proper acceleration, all frames agree.
