Four Circle Problem
  • Level: High School
  • Thread starter bob012345
9 replies · 4K views · last reply
bob012345
TL;DR
Determine the fraction of the darker area to the total area of the figure.
This is a little exercise for fun. Determine the area of the darker petals to the total area. The four circles are identical. Have fun!
Four identical translucent blue circles arranged in a cross pattern, each overlapping its two neighbours to form four darker lens-shaped petal regions where they meet.
Each half a petal is bounded by a chord and a 90-degree slice of the circle. So the area would (pi (r^2)/4) - (r^2)/2 = (r^2)(pi/4 - 1/2). Since there are 8 of those, the total petal area is 8(r^2)(pi/4 - 1/2)=(2pi-4)(r^2).
The total area is 4 circles minus the overlap: 4pi(r^2)-(2pi-4)(r^2) = (2pi+4)(r^2).
Dark petals to total area is: (2pi-4)(r^2)/(2pi+4)(r^2) = (2pi-4)/(2pi+4) = (pi-2)/(pi+2)
bob012345 said:
TL;DR: Determine the fraction of the darker area to the total area of the figure.
This is a little exercise for fun. Determine the area of the darker petals to the total area. The four circles are identical. Have fun!View attachment 371094
Three diagrams in sequence, linked by double arrows: a fan shape with a large arc labelled 2B and two small arcs labelled A; the two small arcs rearranged into one piece labelled B and A; and a quarter-circle style shape split by a line into a region labelled A and a region labelled B.
## \begin{align}
f=&A/(A+B)\nonumber\\
=&(r^2\pi/4-r^2/2)/(r^2\pi/4+r^2/2)\nonumber\\
=&(\pi/4-1/2)/(\pi/4+1/2)\nonumber\\
=&(\pi-2)/(\pi+2)\nonumber\\
\end{align} ##
If anyone is interested, here is the case of five identical circles with a common point as in this diagram. Notice that there are now two levels of petals, the larger and the smaller. In this case determine the fraction of the figure with any petals to the whole figure.
Five identical translucent blue circles arranged in a ring, all passing through a common point at the centre, overlapping to form petal-shaped lens regions.
I got ##\large \frac{2\pi- \gamma}{3\pi+\gamma}## with ##\gamma=5/4\left(\sqrt{10+2\sqrt{5}}-\sqrt{10-2\sqrt{5}}\right )##
Which is about .4
CORRECTION:
I get ##\large \frac{2\pi- \gamma_1}{2\pi+\gamma_2}## with ##\gamma_1 =5/4\left(\sqrt{10+2\sqrt{5}}-\sqrt{10-2\sqrt{5}}\right)## and ##\gamma_2 =5/4\left(\sqrt{10+2\sqrt{5}}\right)## which gives 0.40466…
Three-panel diagram on grid paper: a shape split into regions labelled 2B and 2A, an arrow to a half-version with regions B and A, then an arrow to a further split into A1, B and A2.
Geometry diagram of a circular sector split by two chords into regions A1, B and A2, with a 72° central angle and a 36° angle marked, beside derivations of A1, B, A2 and the ratio f ≈ 0.405.
My answer was actually <0.4 at about 0.3974 so I am investigating my math…
EDIT: I did the calculation another way and agree with @Gavran.
I worked up the general case for integer ##n## overlapping circles. Here is the Desmos page;
The red circle is the generator of the ##n## overlapping circles.
The formula ## f=(\pi/5+\sin72^\circ/2-2\sin72^\circ\sin^236^\circ)/(\pi/5+\sin72^\circ/2)\\ ## from post #6 can be transformed into a general case.
## \begin{align}
f=&(\pi/n+\sin(2\pi/n)/2-2\sin(2\pi/n)\sin^2(\pi/n))/(\pi/n+\sin(2\pi/n)/2)\nonumber\\
=&(\pi/n+\sin(2\pi/n)/2-\sin(2\pi/n)(1-\cos(2\pi/n))/(\pi/n+\sin(2\pi/n)/2)\nonumber\\
=&(\pi/n-\sin(2\pi/n)/2+\sin(4\pi/n)/2)/(\pi/n+\sin(2\pi/n)/2)\nonumber\\
=&(2\pi-n\sin(2\pi/n)+n\sin(4\pi/n))/(2\pi+n\sin(2\pi/n))\nonumber\\
\end{align} ##
The final result is the same as the one in post #8.
The formula produces the fraction ## f=1 ## for ## n=2 ##; therefore, the formula is not valid for ## n=2 ## because the fraction equals ## 0 ## in this case.
Also, the formula produces the fraction ## f=(4\pi-6\sqrt3)/(4\pi+3\sqrt3) ## for ## n=3 ##; therefore, the formula is not valid for ## n=3 ## because the fraction equals ## (2\pi-3\sqrt3)/(4\pi+3\sqrt3) ## in this case.
The formula holds for ## n\ge4 ##.
It can be shown that the fraction approaches ## 1 ## as ## n ## approaches infinity, which is obvious.
Thanks @Gavran for pointing out those cases. In my formulation, I computed the largest petal and the next largest petal which accounts for the overlap of the largest petals. Those overlaps don't exist for ##n=2,3##. The angle of the circular segment making the smaller petal goes as ##\pi-\frac{4\pi}{n}## which becomes negative for ##n<4## yet the formula gives a value that throws things off unless that contribution is zeroed out. If one carefully leaves out just the overlap for those cases it does give the correct answer.
Also obvious is that as ##n## approaches infinity, the total area of the figure approaches ##4\pi R^2##.
