Four-point flexural test - Please help me understand
  • Thread starter Thread starter Rich76
    Test
The four-point flexural test calculates flexural stress using the formula: stress = force x length / (width x (depth x depth)). In this discussion, a failure point force of 42,000 N, support span of 3,000 mm, width of 152 mm, and depth of 269 mm yield a calculated stress of 11.45572 MPa. The term "failure point" refers to the load at a specific point on the load-deflection curve. Understanding this calculation requires familiarity with free body diagrams (FBD) and the area moment of inertia.
  • Understanding of four-point bending mechanics
  • Knowledge of free body diagrams (FBD)
  • Familiarity with area moment of inertia concepts
  • Basic principles of structural engineering
  • Research the calculation of flexural stress in reinforced concrete
  • Study the principles of free body diagrams in structural analysis
  • Learn about the area moment of inertia and its applications
  • Explore the significance of flexural stress values in material science
Structural engineers, civil engineering students, and professionals involved in material testing and analysis will benefit from this discussion.
Rich76
According to wikipedia, this is how to calculate flexural stress where "the loading span is 1/3 of the support span (rectangular cross section)":
Stress ("outer fibers at midpoint"), (MPa)
Force ("load at a given point on the load deflection curve"), (N)
Length ("Support span"), (mm)
Width ("Width of test beam"), (mm)
Depth ("Depth or thickness of tested beam"), (mm)
Source: https://en.wikipedia.org/wiki/Four-point_flexural_test
Plugging in the numbers from this youtube video (four-point test of reinforced concrete):
Force = 42000 N (failure point)
Length = 3000 mm
Width = 152 mm
Depth = 269 mm
stress = 42000 x 3000 / (152 x (269 x 269))
stress = 11.45572 MPaI have two questions:
1. Is the math correct (I'm assuming "failure point" is "the load at a given point on the load deflection curve")?
2. What does a flexural stress of 11.45572 MPa mean? 11.45572 MPa "outer fibers at midpoint"?
The Wikipedia article is poorly written because it assumes that the reader fully understands free body diagrams (FBD) and area moment of inertia (search those terms). In order to calculate stress in four point bending, you need the distance between beam supports, the distance between the two loading points, and if the loading points are centered between the beam supports. Search free body diagram four point bending, then read the Wikipedia article very carefully. You could get a better answer if we had some idea of your background.
  • · Replies 17 ·
16K
14K
