- 19
Hi everyone. I have a Fourier series problem from an old Physics GRE that I would like to discuss.
Here is a link to the problem and a solution. The answer they get is correct, but their explanation is not:
http://grephysics.net/ans/9277/39
Fourier Analysis, but we should be able to solve this without too much math.
Since, you only have 1min. 15s for every problem on the test, usually these problems can be solved in that length of time.
So, I am trying to find a way to get to the correct answer by using reasoning and elimination instead of actually integrating to find the correct coefficients (time consuming). Here is where I am at:
You can eliminate all choices except for A and B since the terms in the series must be odd functions since the function we are expanding is odd.
Now, I can't seem to find a good way to narrow the answer down to B, which is the correct answer. Their explanation does not make sense, since if A is trivially 0 then so is B.
Does anyone here have any ideas? I have been staring at this for quite some time. Yet, I can't find a good way to eliminate A, except by brute calculation of the series. Any thoughts and help will be appreciated. Thank you.
