Fourier transform of a shifted and time-reversed sign
The discussion revolves around finding the Fourier transform of a shifted and time-reversed signal, specifically g(a-t), based on the known Fourier transform G(f) of the original signal g(t). Participants explore the properties of the Fourier transform relevant to this transformation.
  • Participants discuss the application of the shift and time scaling properties of the Fourier transform. There is an attempt to express g(a-t) in terms of g(t) and to derive its Fourier transform using these properties. Some participants suggest rewriting the signal to facilitate the application of these properties.
There is a productive exchange of ideas regarding the application of the Fourier transform properties. Some participants provide insights into the relationship between the transformed signals, while others question the completeness of the proposed solutions and suggest further elaboration on the time-reversal property.
Participants note the need for clarity on the exponential factor that may be involved in the transformation process. There is an emphasis on ensuring that all properties are correctly applied in the context of the problem.
Legend101
given a continuous-time signal g(t) . Its Fourier transform is G(f) ( see definition in picture / "i" is the imaginary number) . It is required to find the Fourier transform of the shifted-time-reversed signal g(a-t) where a is a real constant .
That is , find the Fourier transform of g(a-t) based on the knowledge of the Fourier transform G(f) of g(t)
The defition of the Fourier transform is shown in the attached picture
There are 2 properties of the Fourier transform : shift property + time scaling.
But I'm not sure how to use them both . I prefer to use the definition of the Fourier transform to find the relationship between the Fourier transform of g(a-t) and the Fourier transform of g(t)[/B]
So you know ##\mathcal{F} \{g(t) \} = G(f)##.
Try writing this:
$$g(a - t) = g((-1) (t - a))$$
Now you can use both the time scaling and time shifting properties.
Try writing this:
Can you check the workout i did in the picture below ?
The time scaling property states:
$$\mathcal{F} \{g(\alpha x) \} = \frac{1}{|\alpha|} \hat G \left( \frac{f}{\alpha} \right)$$
You know ##\mathcal{F} \{g(t) \} = \hat G(f)## and ##g(a - t) = g((-1) (t - a))##.
Let ## u = t - a##. Then ##g((-1) (t - a)) = g((-1)u) = g(\alpha u)## with ##\alpha = -1##.
Then you know ##\mathcal{F} \{g(\alpha u) \} = \frac{1}{|\alpha|} \hat G (\frac{f}{\alpha}) = \hat G (-f)##.
This amounts to saying: Since you know ##\mathcal{F} \{g(t) \} = \hat G(f)##, then you can simply apply a negative sign to the argument and get ##\mathcal{F} \{ g(a - t) \}##.
There has to be an exponential factor . Did you check my solution ?
The solution is fine, I thought it would be insightful to elaborate on the time-reversal property where ##\alpha = -1##.
