Fourier transform of church function
In summary: The Fourier transform of the modern church function is given byF(s) = 2 + \text{sinc}_{something} - 2 \cdotsYour derivative looks right. Your proposed solution also looks to be on the right track, although the Fourier transform of the second impulse isn't simply -2. There is also a phase component.
hadoque
43
Fourier transform of "church" function
This is an old examn question that I'm trying to solve. There is a solution, but I'm having a hard time getting it since there is only some kind of graphic equation with no explanation. To only test in the solution is "Derivate!"
Determine the Fourier transform of the following modern church function
http://www.apspektakel.com/bilder/churchf.svg
[tex]
F(s) = \int ^\infty _{-\infty} f(x) e ^ {-i2\pi xs} dx[/tex]
[tex]
i2\pi sF(s) = \int ^\infty _{-\infty} f'(x) e ^ {-i2\pi xs} dx
[/tex]
This is what I think the derivative of the church function would be. I coloured the impulses red, so that their origins are visible. Is the derivative correct?
http://www.apspektakel.com/bilder/churchfd.svg
So, the next step, would it be adding the transform of the first impulse to the transform of the first square, to the second impulse and so on?
I mean would the correct way be something like:
[tex]
i2\pi sF(s) = 2 + \text{sinc}_{something} - 2 \cdots
[/tex]
Another way to do this without derivatives and impulse functions is to express the function as a sum of various rectangles and triangles. Each rectangle's Fourier transform is a sinc function with some scale factors and a phase factor. How about the triangles?
Well, the intergral of a right triangle is just the integral under a straight line function, f(x) = kx+m.
If the left bottom corner of the triangle is a, the bottom right is b and the triangle sits on the positive x-axis: f(x) = kx-ka (since x=a when f(x)=0).
I transform this to
[tex]
F(s) = \frac{k}{i2\pi s} \left ( e^{-i2\pi bs} (1+a-b) -e^{-i2\pi as} \right )
[/tex]
Anyone recognise this to be true? I didn't find this transform tabulated anywhere, so I need to be sure it's correct...
I got something more complicated than that, although it's possible that it simplifies to your answer.
It's easier if you define the triangle to sit between x = 0 and x = c. Then if you need to shift or scale it, you can use the standard Fourier transform properties.
In this case, you will have
[tex]\int_{0}^{c} kx e^{-i2\pi s x} dx[/tex]
You can use integration by parts. Wolfram Alpha gives
[tex]\frac{1}{4 \pi^2 s^2} [2\pi i c s k e^{-i2 \pi c s} - k(1 - e^{-i2\pi c s})][/tex]
which can be further simplified using the typical tricks, e.g.,
[tex]1 - e^{-ix} = e^{-ix/2}(e^{ix/2} - e^{-ix/2}) = 2ie^{-ix/2} \sin(x/2)[/tex]
What syntax did you use to get wolfram alpha to produce that?
Here is what I typed:
integrate (k*x*e^(-i*2*pi*s*x) from x = 0 to x = c
Cool! I'll start using wolfram alpha :) Thanks for the help.
For the function f(x) = (x-a) if a < x < b and f(x) = 0 elsewhere, Maple 14 gets:
f1:=(x-a)*Heaviside(x-a)*Heaviside(b-x);
f1 := (x - a) Heaviside(x - a) Heaviside(b - x)
J2:=fourier(f1,x,w) assuming b>a;
J2:= I*exp(-I b w) (-w a - I + b w)/w^2 - exp(-I w a)/w^2
where I = sqrt(-1).
RGV
marcusl said:
I might point out that this is easier than you are making it. Write the triangle as a convolution of two rectangles
/\ = rect * rect
Use the convolution theorem to find the transform, and the answer falls right out.
That's true for a triangle shaped like this: /\, but not for one shaped like this /|. The latter type is what appears in this problem.
My mistake, I didn't see the shape listed anywhere. I've deleted my earlier post.
1. What is a Fourier transform of a church function?
A Fourier transform of a church function is a mathematical operation that decomposes a complex function into its constituent frequencies. It is commonly used in signal processing and image analysis to analyze and manipulate data.
2. How is a church function related to the Fourier transform?
A church function, also known as a rectangular function, is a mathematical function that is equal to 1 within a certain interval and 0 outside of that interval. The Fourier transform of a church function is a sinc function, which is a periodic function that represents the amplitude of each frequency component in the original signal.
3. Why is the Fourier transform of a church function important?
The Fourier transform of a church function has many practical applications, such as filtering noise from signals, compressing data, and analyzing the frequency content of images. It is also a fundamental tool in solving differential equations and understanding the behavior of systems in the frequency domain.
4. How is the Fourier transform of a church function calculated?
The Fourier transform of a church function can be calculated using the Fourier transform formula, which involves integrating the function over its entire domain. This can be done analytically or numerically using various mathematical software packages.
5. Are there any limitations to using the Fourier transform of a church function?
One limitation of using the Fourier transform of a church function is that it assumes the function is periodic, which may not always be the case in real-world applications. Additionally, the Fourier transform may not accurately represent signals with discontinuities or sharp edges, which can result in artifacts in the transformed signal.
